| K750i lens cover coming a bit loose??
I have had my k750i for about 3 weeks now, and in the last week I have noticed how the camera lens on the back seems to be coming loose. For example when the cover is open for taking a photo if you press down on the end it can rock up and down, a bit like a see-saw if you get what I mean. When it is closed, it can also rock up and down. It doesn't move up and down an extreme amount, just enough to see it and also to feel it. For example when using the phone sometimes it moves and makes a creaking noise, which is every so slightly annoying.
Is it supposed to be like this, or is it just coming loose ??
