AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 18-01-2006, 10:05 PM   #1 (permalink)
Thanks: Gave 1, Got 3
Connecting Ipaq to Nokia to use GPRS help please.
Hi I have a Ipaq h6340 pocket PC that has a sim slot and a 6230i Nokia.
My problem is I need to have the phone (has handsfree kit in car) and Ipaq to send emails. Having another sim isnt an option as they wont provide us with one (long story we tried). SO I need to get the ipaq to talk to the phone and use its gprs to send emails.
Ive been trying for a while but no success. I can get it to send pics from phone to ipaq ok though.
Can anyone help and advise what settings I need to change as the sim swapping is driving me mad.
Thanks in advance
ScoobyZ
ScoobyZ is offline
Old 25-01-2006, 12:06 AM   #2 (permalink)
Jaffatubes's Avatar
Thanks: Gave 1, Got 10
ScoobyZ,
You don't mention which network you are on, but here goes.......
I have a dell X50v and a Nokia 6310i, on O2, which I can use to get my company emails over GPRS.
By the sounds of it you have already passed the first hurdle in getting your phone to communicate with the PDA over Bluetooth, but you need to be able to access the phone from the IPAQ as a dial up modem using bluetooth to be able to use it to send emails. If the IPAQ is Windows Mobile 2003se as I suspect it is, then you should be able to Google search about to get a script which talks you through how to achieve this. Try www.ipaqhq.com or www.aximsite.com for example, many people have done it, it is trying to find someone with a combination which is the same or very similar to your hardware that's the problem.
Once you can access the phone over bluetooth using it as a dialup modem, you then need the correct GPRS settings to access the internet programmed into your IPAQ - as if you were sat at your normal PC accessing the internet over dialup. These settings are different to the WAP settings that your provider will send to you via sms, located on your phone - they don't work.
Now, each service provider has it's own set of details, IP's, logins and passwords to enable you to do this. I did a google search again when I tried and their was a lot of different info out their to do with O2, none of which worked with me. In the end I phoned O2 and found out they have a GPRS helpdesk which can talk you through the exact process step by step as long as you can tell them which software and hardware versions you have on Ipaq and phone etc.
If you are on O2, then let me know, and I'll dig out the details for them, otherwise give them a ring, they were very helpful.
Once you get it up and running, be prepared for variable coverage around the country for GPRS - it is much more susceptible to bad signal areas and busy networks, especially if you are in the car - doesn't like moving from cell to cell whilst trying to download I've found. It is also very slow - much less than dialup internet.
Hope this helps some.
Hitachi 32LD7200 LCD, Yamaha DSP757SE, Panasonic DMREH60D, SKY HD, XBOX 360 Elite, Mordaunt Short Genie 5.1, IPOD Photo 30GB, Nikon D70, Dell Axim X50V.
Jaffatubes is offline
Old 12-02-2006, 6:06 PM   #3 (permalink)
Thanks for that,
sounds complicated.
I'm on with vodaphone. Will have another go when I have time, but a couple of us have ried different things and we are still sim swapping.
ScoobyZ
ScoobyZ is offline
connecting, gprs, ipaq, nokia
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
