| AVForums.com is the UK's biggest & best home consumer electronics discussion resource | New to AVForums.com? Start by reading our introduction here. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
iPaq H5550 and GPS Satnav help
I bought this http://www.mobilefun.co.uk/product/8590.htm to use with my ipaq and I can connect and paired it.
__________________I have MS Pocket Streets on my PocketPC which is essentially a PocketPC version of Autoroute with support for GPS. I know the GPS unit is working okay as I also paired it with my Desktop PC which has a bluetooth dongle and I started Autoroute on the PC and got a fix on the GPS unit viewable on-screen within Autoroute. When I paired the GPS with my Desktop it allowed me to pick the serial port to use (COM4). When I paired it with my iPaq and connected I started Pocket Streets and under "Configure GPS receiver" it allows me a choice of 3 serial ports... COM1,COM3,COM9 I have tried all 3 but it will not connect...how can I find which serial port the GPS wants to use...I was able to select COM4 with my Desktop? Or, is there a setting in the ipaq where I can select a different serial port? Within the iPaq if I go in to "Settings", "System", "Bluetooth" under "Serial Port" under "Ports" is Inbound Com Port 5 Outbound Com Port 8 Can anyone tell me if these are fixed?...I thought I could bring up the soft keyboard and change them but it won't allow me. JayCee -------------------------------------------------- Please note that any views expressed are my own personal opinions and not those of the AVForums Last edited by JayCee; 17-01-2006 at 2:32 PM. |
| Bookmarks |
| Tags |
| gps, h5550, ipaq, satnav |
| Thread Tools | |
| Display Modes | |
Global Gold Web Hosting |
