Originally Posted by ANDY DUTTON
thanks for that reply
ps ; sorry if ive posted on the wrong thread
No problem,
No no, you've posted in the right section, I think that pjclark just assumed that you were trying to get pirated software to work.
N70 and Tomtom functionality is a known issue.
*EDIT* Also make sure that your RS-MMC card is a dual voltage type otherwise your N70 won't touch it. The card needs to be labelled as RS-DV-MMC, DV-RS-MMC or MMC Mobile and be able to function at 1.8V as well as 3.6V.
S.
