13-01-2006, 1:27 PM
#1 (permalink)
Wanted: Blue Tooth GPS
I looking to buy a good blue tooth gps to work with tom tom5...anybody got anything to offer or know where i can get a good/reasonably priced one from?
13-01-2006, 3:49 PM
#2 (permalink)
Thanks: Gave 85, Got 533
I use one of these http://www.mobilefun.co.uk/product/8590.htm , get 4-5 Sat fixes on mine even when in the car glove box. works a treat with my XDA Mini S.
delivered to my door 18hrs after i bought it online, excellent service
PSN - Uridium_UK
13-01-2006, 4:35 PM
#3 (permalink)
Thanks: Gave 73, Got 741
Do you know if it will work with my HP iPaq H5550...any incompatability problems?
JayCee
Please note that any views expressed are my own personal opinions and not those of the AVForums
13-01-2006, 4:42 PM
#4 (permalink)
Sorry only tried it with MyXDA Mini S
PSN - Uridium_UK
13-01-2006, 4:53 PM
#5 (permalink)
thanks for this, need to look at if it will work with my Dell X50 and tom tom 5...
did you buy one from the place on the link?
13-01-2006, 5:52 PM
#6 (permalink)
Yup, excellent service as well, like I said delivered to my door only 18 hours after I bought it online.
PSN - Uridium_UK
13-01-2006, 7:30 PM
#7 (permalink)
Thanks: Gave 586, Got 346
i have the tomtom GPS 9821x (the rectangel small one) with car cahrger i used it for my HP4150 and i have the car charger that charges this and the HP4150 at the same time. how much would you be looking to spend?
Linn Kolektor pre amp & LK140 amp,Genki,Sony MD MDS JE510,Roku Sound bridge M1000,Ariston RD-40 turntable,TDL RTL3 ,Samsung32R87, Yamaha YSP-1000,Panasonic PT-AX100E projector,Toshiba HD-E1 ,Sky HD, XBox 360, PS3,Harmony 885
14-01-2006, 9:03 AM
#8 (permalink)
Ebay m8ey - i got one for 50 Kangaroos with a 30 hr charge on it
cheers
LH
ps i also got mem card for Nokia 6680 with Tom Tom Mobile 5 on it for 19.99
l8r
17-01-2006, 8:28 AM
#9 (permalink)
Thanks for the advice guys, looking to spend around £50
24-01-2006, 8:37 AM
#10 (permalink)
Thanks: Gave 4, Got 0
There are a couple of makes on ebay, the cheaper one also uses a nokia battery (from 8210,8310)
24-01-2006, 12:19 PM
#11 (permalink)
The £40 one posted earlier from Mobile fun also uses a Nokia comaptible battery (BL-5C from memory). also uses a Mini USB socket to charge (same as XDA Mini S and XDA Exec so bonus is you get a free car charger for your XDA!!
PSN - Uridium_UK
