Removing O2 software from XDA Mini S
Old 09-01-2006, 1:55 PM   #1
Uridium's Avatar
33,239, Level: 44
Points: 33,239, Level: 44 Points: 33,239, Level: 44 Points: 33,239, Level: 44
Activity: 20.6%
Activity: 20.6% Activity: 20.6% Activity: 20.6%
Thanks: Gave 527, Got 1,810
After trying various options from the O2 Extended Rom builds here's a guide for any new XDA Mini S owners trying to get the device to run the way it should!
Main thing to do when it arrives is NOT to use the appalling O2 active build it will arrive with as it cripples the OS (don't know what O2 were thinking!
When you start it up and the Extended rom install starts it will give you a chioce of Basic/Corporate or Standard installation. Choose BASIC as this will install minimal O2 stuff. If you choose corporate you will not get any GPRS settings or the MMS application.
Once the basic install has completed browse to the Windows\startup folder using the built in File explorer application and delete the 2x O2 icons, then open the remove programs application and remove any O2 programs in there as well
Now do a soft reset and you'll have a nice clean install the way the device was intended to be.
Take a look at the "Wizard" forums here for anything you'd ever need to know about this device
adlersc (06-06-2006), pyromania (11-09-2006)
Old 26-01-2006, 7:05 PM   #2
newstuart's Avatar
8,172, Level: 21
Points: 8,172, Level: 21 Points: 8,172, Level: 21 Points: 8,172, Level: 21
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 44, Got 35
Looks good, is there anyway to do this if i have allready used the o2 auto install feature ?
Old 02-02-2006, 5:51 PM   #3
5,007, Level: 16
Points: 5,007, Level: 16 Points: 5,007, Level: 16 Points: 5,007, Level: 16
Regrettably I didn't get a choice. it locked the keyboard and did its own thing despite bashing the screen trying to change from the default.
Any suggestions as per the last entry in removing it after install because its definately crippled
Old 02-02-2006, 6:39 PM   #4
5,007, Level: 16
Answered the question myself. My advice don't ever put a pin protection during install because it locks the screen from input!
First stop any pin numbers from being required after a given amount of time in the settings.
Do a hard reset. Ignore the book which says switch the device off first. If you do this first it won't hard rest. So hard reset from the on position.
The machine will start with a clean machine. Decline any options to install any pin number protection. this will simply stop you accessing the screen later on when it asks about which type of install.
Eventually it will offer you a basic install amongst the options. Take this option because the default makes the device unusable.
Haven't done it yet but i will next be following the initial advice given earlier.
Old 07-02-2006, 9:24 AM   #5
rayc's Avatar
2,259, Level: 11
Points: 2,259, Level: 11 Points: 2,259, Level: 11 Points: 2,259, Level: 11
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 1, Got 3
cheers
thanks uridium.
my xda mini was just about to go back.
only had it for a couple of days and couldnt beleive how slow and buggy it was.
ditching the o2 stuff has made a vast improvement.
one thing you might be able to help with
when i explore my device using activesync i cant find the windows folder(want to add ringtone).yet i can find it using file explorer on the device itself.
any ideas?
thanks
ray
Old 07-02-2006, 1:11 PM   #6
Uridium's Avatar
33,239, Level: 44
Activity: 20.6%
Haven't got my Sych cable to hand but seem to recall if you click the top left folder in activesync explorer folder (could be "my device" or similar) you'll find it under there.
to add MP3/WMA/WAV's as ringtones you can always just copy the MP3 to your storage card or somewhere then in file explorer on the XDA tap and hold on the MP3 and in the menu that pops up will be an option "Set as ringtone". This will copy the file to \Windows\Rings for you automatically.
Old 07-02-2006, 5:56 PM   #7
rayc's Avatar
2,259, Level: 11
Activity: 1.5%
tks
windows folder still not there for some reason.
copied it to my docs and got the set as ringtone option.(was trying to do that in the media player).
do you know any other sites or forums for the xda mini apart from xda developers?
Old 08-02-2006, 6:56 AM   #8
29,731, Level: 42
Points: 29,731, Level: 42 Points: 29,731, Level: 42 Points: 29,731, Level: 42
Activity: 7.6%
Activity: 7.6% Activity: 7.6% Activity: 7.6%
Thanks: Gave 41, Got 207
If you choose co-oporate mode the code is "0506" this will not install any o2 active stive, also you need to get the GRRS settings yourself...
Old 08-02-2006, 8:48 AM   #9
newstuart's Avatar
8,172, Level: 21
Activity: 0.7%
quote
"Answered the question myself. My advice don't ever put a pin protection during install because it locks the screen from input!
The machine will start with a clean machine. Decline any options to install any pin number protection. this will simply stop you accessing the screen later on when it asks about which type of install."
When you say do a hard reset could you explain how this is done ? I have just been holding down the reset button and this just seems to re-boot exactly the same as it was before
Old 08-02-2006, 8:51 AM   #10
29,731, Level: 42
Activity: 7.6%
check on xda-developers.com
I think it is the wirleess manager key and voice command and the reset, maybe the power to...
Old 08-02-2006, 9:59 AM   #11
Uridium's Avatar
33,239, Level: 44
Activity: 20.6%
Believe the Corporate mode doesn't install the MMS app either (I maybe wrong though!)
Old 10-02-2006, 3:00 PM   #12
newstuart's Avatar
8,172, Level: 21
Activity: 0.7%
Just got a new one as the old one kept freezing - I havent turned it on yet, any other tips for speed and realibility before I do ?
Old 10-02-2006, 8:05 PM   #13
Uridium's Avatar
33,239, Level: 44
Activity: 20.6%
Once you've removed the O2 stuff, get hold of a copy of an application closing tool like "Magic Button" or "SPB Pocket Plus".
These programs will actually close applications on you XDA properly (windows mobile actually just minimizes programs when you close them).
I use SPB pocket plus and have it set to close all apps when I press the X apart from internet explorer, messaging & phone.
makes it run MUCH faster.
Old 11-02-2006, 2:22 AM   #14
29,731, Level: 42
Activity: 7.6%
Jut got hold of a different ROM "OS", the Qtek version, way better than the O2 one, much faster, and no slow synching with the PC and no crashing of outlook after a sync, i'd advise you all try this rom, also supports Push Email and A2DP, instructions here..
http://forum.xda-developers.com/viewtopic.php?t=40458
Old 27-02-2006, 10:31 AM   #15
roy748
Posts: n/a
New XDA mini
Hello there, new member so please forgive any ignorance I may demonstrate. I have today taken delivery of a 02 XDA mini and having read your comments and keen to get the best out of it. Uridium suggest installing in basic mode, sounds good but not knowing anything really about the mini other than it looks great, will setting up in this mode affect my use in regards to 02 services, being that I dont really know its capabilities, as a complete novice would I be better installing 02 active, what would I lose if I choose basic over 02 in regards to 02 links.
Thanks for your help in advance.
Old 28-02-2006, 8:14 AM   #16
scotts1984
Posts: n/a
xda mini s
Iv only had the xda mini s for about 2 weeks and I'm really happy with it! best thing ya can do is choose basic mode because all the o2 stuff is junk and you will nether use it anyway! plus it runs better without it. I found I could not set a image properly as my background but since I removed the o2 software it works! I'm sending this reply from my xda mini s now! its so cool!
Old 28-02-2006, 8:23 AM   #17
scotts1984
Posts: n/a
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Old 28-02-2006, 8:18 PM   #18
29,731, Level: 42
Activity: 7.6%
i'd go for the co-oporate install as being a newbie, no ffence you might have trouble getting rid of the crappy O2 software which really slows down the device, I can give oyu the GPRS settings if needed....use the code "0506" for the co-oporate install...
Old 28-02-2006, 11:50 PM   #19
Uridium's Avatar
33,239, Level: 44
Activity: 20.6%
Do you not think that being a "Newbie" manually inputting the GPRS info, creating the connections and installing the CAB files for the MMS app would cause even more confusion
I still say until your familiar with the OS and the device go for the basic install
Old 01-03-2006, 1:39 PM   #20
29,731, Level: 42
Activity: 7.6%
Forget the basic install, that O2 software would but the newbie straight off the phone, i'll give the dude the GPS settings and tell him how ot input them, it's far more easier than removing the O2 software...unless you want to tell him how to do it...
Old 01-03-2006, 6:09 PM   #21
Uridium's Avatar
33,239, Level: 44
Activity: 20.6%
already in post no.1 (that's what the post started with!)
Old 01-03-2006, 6:39 PM   #22
29,731, Level: 42
Activity: 7.6%
where did the guy go anyway, he hasn't posted in a while?...
Old 01-03-2006, 9:51 PM   #23
Uridium's Avatar
33,239, Level: 44
Activity: 20.6%
probably still hunting around the Mini S looking for the stylus
Old 02-03-2006, 8:09 AM   #24
scotts1984
Posts: n/a
o2 software
Its easy to remove the o2 software. Just follow the instructions of the first post. If you want to get rid if the o2 icons in programs just goto the folder windows/startMENU and remove the o2 icons from there.
Just because your a newbe it doesnt mean ya stupid. i agree ,it would be much harder to setup the grps & mms setting than to remove the o2 software.
Old 02-03-2006, 3:44 PM   #25
29,731, Level: 42
Activity: 7.6%
setting up the GPRS settings is easy, just getting them is a problem, I had t ohard reset back to the O2 rom just to get the settings as non one gave the right settings, then I had to reinstall the Qtek AKU2 Rom, and yes i wrote the settigns down and where to put them...
Old 02-03-2006, 6:49 PM   #26
scotts1984
Posts: n/a
Il give it a try then! could you please post the settings please
Old 02-03-2006, 9:14 PM   #27
29,731, Level: 42
Activity: 7.6%
GPRS
ISP: Mobile Web
mobile.02.co.uk
username: o2web
Password: password
193.113.200.200
193.113.200.201
Wap
Connection:work
ISP:o2active
wap.o2.co.uk
username: o2wap
password: password
proxy, 193.113.200.195:9201
mms
O2UK
193.113.200.195
http://mmsc.mms.o2.co.uk:8002
Old 02-03-2006, 9:23 PM   #28
scotts1984
Posts: n/a
o2 xda mini gprs settings
O2 XDA mini s GPRS & MMS settings & instructions (windows mobile 2005)
1. Navigate to start menu settings connections
2. Click the Connections icon
3. Click Advanced tab
4. Click Select Networks
5. Programs that automatically connect to the internet should connect using: Click Edit (the top 1)
6. Click New
7. Enter name as "Mobile Web" & select a modem should be "cellular line (gprs)" Click Next
8. Access point name should be "Mobile.o2.co.uk" Click Next
9. o2 user name should be "o2web" & password should be "password" Click Advanced
10. Select Severs tab then select button "use specific server Address"
11. DNS should be "193.113.200.200" & alt DNS should be "193.113.200.201"
12. Click ok (top right) Click Finish.
MMS Settings:
1. Navigate to Start messaging menu MMS Configuration
2. Click Select Servers tab and click on o2uk at the top
3. Sever name: O2UK
Gateway: 193.113.200.195
Port number:9201
Server address: http://mmsc.mms.o2.co.uk:8002
connect via: my work network
sending size limitation: 100k
wap version: WAP 1.2
4. Click ok
Old 02-03-2006, 9:25 PM   #29
scotts1984
Posts: n/a
thanks as you can see i just did it the same way u did. noted down the settings!!! you are right it is alot better! thanks
Old 03-03-2006, 8:03 PM   #30
scotts1984
Posts: n/a
Thumbs down battery icon gone
Hmm one problem with corprate mode i lost my battery life bar. I did notice there was a little icon at the bottom right but even that has gone now! Not very good. But still at least the o2 stuff is gone! Any ideas?
Powered by
 Latest popular product prices
Nokia 1800
2 prices from
 £28.99 Click to show/hide the offers
Nokia 6303i classic
1 price
 £100.99 Click to show/hide the offers
Nokia 500
2 prices from
 £119.95 Click to show/hide the offers
Blackberry Curve 8520
3 prices from
 £147.99 Click to show/hide the offers
HTC Wildfire S
4 prices from
 £154.99 Click to show/hide the offers
Blackberry Curve 3G 9300
3 prices from
 £174.99 Click to show/hide the offers
Samsung Galaxy Ace GT-S5830
4 prices from
Blackberry Bold 9780
2 prices from
 £287.49 Click to show/hide the offers
 Updated February 13th at 3:30pm. Prices include delivery.
