Unlocking D500
Old 28-12-2005, 5:21 PM   #1
Michaelknell's Avatar
9,868, Level: 23
Points: 9,868, Level: 23 Points: 9,868, Level: 23 Points: 9,868, Level: 23
Thanks: Gave 43, Got 17
Unlocking D500
Anyone used this site and know what I'd have to do to unlock the Samasung D500? There is a file I have downloaded at the bottoom but I don't know what to do.
Also, is it legal?
Old 29-12-2005, 11:34 PM   #2
3,241, Level: 13
Points: 3,241, Level: 13 Points: 3,241, Level: 13 Points: 3,241, Level: 13
Thanks: Gave 3, Got 69
Also, is it legal?
its not illegal to unlock your phone (although you maybe using some cracked s/w to do it from there)
you would also need the correct cable to unlock, and you can get another cable to reflash the phone to remove the branding as well
i use d500 winimei to unlock but if you not confident then i would either get soemone to do it for you or get a clip which plugs into the phone and you wait a few secs then its unlocked, then sell the clip on to someone else. clip is about £15
Old 20-03-2006, 4:08 PM   #3
9,517, Level: 23
Points: 9,517, Level: 23 Points: 9,517, Level: 23 Points: 9,517, Level: 23
Thanks: Gave 101, Got 36
I'm trying to unlock a d500 with winimei v1.07 and cable with battery but i'm having problems...
When i switch the phone on i just get the first samsung logo screen stuck on with the backlight flashing on and off every few seconds. I can enter TAT mode and read the imei no problem but it fails after writing.
I have read somewhere that you also need the Bluetooth ID to re-write the imie. Is this the case? All i want to do is unlock it from its current network.
Can someone please explain or point me in the direction of some help.
Old 20-03-2006, 5:29 PM   #4
3,241, Level: 13
Originally Posted by Soldier_I
you dont need to rewrite the imei as i hope you havent changed it.
connect to phone and enter tat and select rd imei setting, this will read the lock code.
you then disconnect phone and put in a sim it doesnt work on then enter the lock code - i think its the 2nd set of numbers along on the network lock line on winimei but it may be the 3rd.
i never had any luck with direct unlock on winimei and found above way works everytime
Old 21-03-2006, 4:27 PM   #5
9,517, Level: 23
Hi, i got the lock code from the network lock line using winimei but how do i enter the code?
I have disconnected from the cable and put a vodafone sim in (phone locked to Orange) powered up and get the first Samsung logo screen and enter the code but nothing happens. I have also tried to enter the 3rd set of digits from the network lock line but nothing seems to work, it just stays on the first screen with the backlight flashing.
What am i doing wrong?
Old 21-03-2006, 8:23 PM   #6
3,241, Level: 13
when you put the voda sim in, it should say something like "enter password" or "network lock"
from memory, i think you then put the code in and maybe press the dial button(?)
ive not had the backlight flashing before, but i notice you had this earlier?
does it work ok on orange still? if not it may need reflashing
Old 21-03-2006, 8:57 PM   #7
9,517, Level: 23
no mate i don't think it does still work on orange.
I doesn't say anything when i put the voda sim in, it just diplays the Samsung logo screen with the flashing light - can't get it to do anything.
How do i reflash the phone?
Old 21-03-2006, 11:07 PM   #8
3,241, Level: 13
this should give you everything you need to know
http://forums.mobiledia.com/topic29450.html
you will need a different cable - best get the usb one as its much quicker
and make sure battey is fully charged before flashing (charge in another phone if you have to)
just to flash one phone may be cheaper to let someone else do it who already has the correct stuff
Old 23-03-2006, 4:07 PM   #9
9,517, Level: 23
Thanks alot m8.... Really appreciated your help!
Sorted now
Old 24-03-2006, 10:51 PM   #10
2,446, Level: 11
Points: 2,446, Level: 11 Points: 2,446, Level: 11 Points: 2,446, Level: 11
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 5, Got 2
Unlock your Samsung without a cable.
This worked for my phone, and it seems like it should work for most Samsungs from what I've seen.
1. Turn off your phone, put in a SIM of a provider that it is not locked to, and turn it back on.
2. At the wrong card message, type *#9998*3323#. A message will pop up telling you to press exit, so hit the right softkey. Choose number 7 (or 8 or 9 work, I think). Your phone will reboot and your SIM will work.
3. Type *0141# and then hit call. This will give you a message saying your phone is personalized.
4. Power down your phone and insert a SIM card other than the one that is in it. Power back up your phone.
5. At the SIM code prompt type 00000000, that is 8 zeroes.
Your phone should now be unlocked. At least mine seems to be. Let me know how it goes.
I GOT A HOLD OF THIS LAST WEEK TO UNLOCK MY WIFES D500 BUT HAVENT TRIED IT YET SO DONT KNOW IFIT WORKS YET. I,LL TRY TOMORROW AND LET YOUS KNOW. AS I SAID I HAVENT TRIED THIS YET FOLKS SO TRY IT YOURSELF AT YOUR OWN RISK.
Old 16-10-2006, 1:23 PM   #11
bunyboy's Avatar
6,062, Level: 18
Points: 6,062, Level: 18 Points: 6,062, Level: 18 Points: 6,062, Level: 18
Thanks: Gave 14, Got 6
Re: Unlocking D500
did it work?
id like to do it with my d500 right now!
Old 16-10-2006, 2:25 PM   #12
3,241, Level: 13
Re: Unlocking D500
the only working code for d500 is #*7337#
and that only worked on the first ones
you can get an unlock clip for £10 and do it yourself in 3 secs then sell the clip again
Old 16-10-2006, 10:33 PM   #13
bunyboy's Avatar
6,062, Level: 18
Re: Unlocking D500
i tried that code and it didnt do anything.. so i guess i need the unlocking clip.. there are 100's all over ebay and a couple of different types as well.. can anyone unlocked their d500 before and can they point me in the direction of a good ebay seller to get one of these unlocking clips from..?
thanks
Old 16-10-2006, 11:01 PM   #14
16,736, Level: 31
Points: 16,736, Level: 31 Points: 16,736, Level: 31 Points: 16,736, Level: 31
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 42, Got 341
Re: Unlocking D500
Originally Posted by bunyboy View Post
u tried that code and it didnt do anything.. so i guess i need the unlocking clip.. there are 100's all over ebay and a couple of different types as well.. can anyone unlocked their d500 before and can they point me in the direction of a good ebay seller to get one of these unlocking clips from..?
thanks
If you give me a pm I may be able to help you out with a clip. I hope that this isn't against forum rules.
Old 18-10-2006, 1:53 AM   #15
Knyght_byte's Avatar
22,868, Level: 36
Points: 22,868, Level: 36 Points: 22,868, Level: 36 Points: 22,868, Level: 36
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 96, Got 655
Re: Unlocking D500
depends, if you are just offering to send him a clip free of charge then i guess its ok providing the phone isnt stolen...
if you want to sell or trade the clip then please go down to the trading forums, cheers. (i assume its allowed to sell them here, although it may not be, not sure where things lie in respect to our trade forums and phone unlockers....perhaps ask one of the trading forum mods before you post a thread)
amend your above post as so neil, ta
Powered by
 Latest popular product prices
Nokia 1800
2 prices from
 £28.99 Click to show/hide the offers
Nokia 6303i classic
1 price
 £100.99 Click to show/hide the offers
Nokia 500
2 prices from
 £119.95 Click to show/hide the offers
Blackberry Curve 8520
3 prices from
 £147.99 Click to show/hide the offers
HTC Wildfire S
3 prices from
 £154.99 Click to show/hide the offers
Blackberry Curve 3G 9300
3 prices from
 £174.99 Click to show/hide the offers
Samsung Galaxy Ace GT-S5830
4 prices from
Blackberry Bold 9780
2 prices from
 £287.49 Click to show/hide the offers
 Updated February 12th at 2:30pm. Prices include delivery.
