Hi.
I tried several set ups and this (at the time )was the best setup for me. It was a Phillips Zenia 6626 base statiion with two seperate handsets (zenia). A doddle to register extra handsets too. Cant see my handsets any more but dont make my initial mistake of getting cheap (low end) phillips handsets that will not operate a 'shared' and 'private' phone book, other wise you will have to input the numbers in each handset manually if you want to use caller id etc. As prev message, these have been bullet proof units in my experience and have used them a circa 200m range with no probs. My handsets have an amplification switch to increase the volume which is also very useful. My two year old has put them through their paces too, with no problems !!!! They also have a 'baby sit' function which allows you to place a handset in the kids room and use it as a baby monitor, which automatically places the handset on silent ring (if you have kids). The best price I found was from DST , link below (if it works!). If not go to
www.home-phones.co.uk and search for the model.
http://www.home-phones.co.uk/asp/pro...=any&PT_ID=all
Just checked site and they are now half of what I paid !!!!! Base station is £17.99 + p&p Not sure if this includes the manual but I could always photocopy it and post it if needed
Good luck and let me know if you want anymore info
Marcus
