Hi all,
I have just bought a CF WiFi card for my Axim X5 and it's connecting fine and browsing the net is a new experience.
The other reason I bought it was to connect to a share on my network and play MP3's direct from there only I'm not having much success?
I can connect to the network share fine, I can see the file in explorer on the PDA but when I click it ...NADA. If I copy the file from there to my SD card it opens fine??
I also get the same when trying to view jpegs...am I fighting a losing battle? Am I trying to do something that can't be done?
Worth mentioning running PPC2002 and also my Windows Media Player is corrupt (won't run - really need to do a hard reset but been putting it off) so I'm using Pocket Music which with it's big buttons (ie ability to use my chipolata fingers
) work well for me.
Any and all advice much appreciated.
Glen
