AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 27-11-2004, 11:48 AM   #1 (permalink)
Thanks: Gave 12, Got 7
DIY Ringtones
Can you make your own ringtones for Nokia phones from mp3 or midi files?
the_sanguine is offline
Old 29-11-2004, 8:41 AM   #2 (permalink)
shoehorn's Avatar
Thanks: Gave 113, Got 17
Not sure if you can for all, but the 6230 can use any MP3 as a ringtone and/or message alert.
England by 3....!!! (22/11/2003)
shoehorn is offline
Old 29-11-2004, 2:10 PM   #3 (permalink)
How do you get them from the PC on to the phone? Do you need the PC suite?
Old 29-11-2004, 2:57 PM   #4 (permalink)
shoehorn's Avatar
Well I transferred a load of tracks onto a MMC for listening to, by using a card reader and my PC.
Then moved the ones I wanted to be used as ringtones as follows:
First select the profile you want the track to be the ringtone for (Menu, Settings, Profiles - select the profile here - Activate)
Once tracks are on the MMC card and in the phone, select:
Menu, Gallery, Memory Card.
Then highlight the track you want for the ringtone, press options and set as ringtone!
Once you take the card out to change tracks, it won't be a ringtone anymore, so for a more permanent solution:
Highlight the track you want, press options then select Move.
Highlight the Music files folder, then press options, highlight Move here and then press select.
Once moved... open the Music files folder, highlight the track you've moved, press options, then select Set as ring tone.
The ring tone is now in the phone memory and will not be 'erased' if you change/remove the MMC.
Hope that makes sense!
Oh - you have to have enough phone memory for the track to be moved in the second example.
So if it won't move that's the reason.
shoehorn is offline
Old 29-11-2004, 3:15 PM   #5 (permalink)
Cheers. I don't have that phone yet but am considering it. It would be cool to have a recording of my own band as a ringtone!
diy, ringtones
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
