AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Mobile Phones and PDAs
Compare Mobile Phones – Mobile PhonesCompare Mobile Phones – Mobile Phones
LinkBack Thread Tools Display Modes
Old 18-11-2004, 11:11 AM   #1 (permalink)
AOD
AOD's Avatar
Thanks: Gave 13, Got 5
Connecting a headset & PDA via BT to mobile
Hi folks,
I have a quick question for anybody with a Bluetooth enabled mobile that also supports GPRS.
If you're connected to the phone with a BT headset (so the phone has an active BT connection), can you also initiate using Bluetooth from say a Pocket PC, a GPRS connection?
The reason I'm interested is that I would like to be able to receive traffic updates on my Pocket PC via GPRS (connecting over Bluetooth). But whilst driving of course I need to retain the use of my Bluetooth headset.
My present phone (a Nokia 6310i) only seems capable of one BT connection at a time. Either you connect with a headset, or a Pocket PC/Computer. You can't do both which seems a little short sighted.
AOD is offline
connecting, headset, mobile, pda
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
