Ipaq/Tomtom info required
Old 06-07-2004, 2:43 PM   #1
roohster2's Avatar
7,601, Level: 20
Points: 7,601, Level: 20 Points: 7,601, Level: 20 Points: 7,601, Level: 20
Just bought an Ipaq 2210 and tomtom3...
Id like to add Speed camera warning to this setup - I know there are quite a few databases out there, but which is the best/simplest to use?
I want something that will integrate with tomtom so I dont have to switch off GPS to get the camera warnings.
Any advice?
Old 06-07-2004, 3:19 PM   #2
6,875, Level: 19
Points: 6,875, Level: 19 Points: 6,875, Level: 19 Points: 6,875, Level: 19
Activity: 10.2%
Activity: 10.2% Activity: 10.2% Activity: 10.2%
Thanks: Gave 77, Got 106
I use the database from Pocket GPS World which integrates with TomTom quite nicely and its free
Old 06-07-2004, 3:21 PM   #3
shoehorn's Avatar
7,987, Level: 21
Points: 7,987, Level: 21 Points: 7,987, Level: 21 Points: 7,987, Level: 21
Thanks: Gave 132, Got 26
save your hard-earned... and don't break the speed limit
Old 06-07-2004, 3:26 PM   #4
6,875, Level: 19
Activity: 10.2%
as i said its free !!
Old 06-07-2004, 4:09 PM   #5
roohster2's Avatar
7,601, Level: 20
Thanks Carlos...
I had a look at that one and it seems like the one to go for.
Could you give me any tips on installing it?
I know the site has instructions, but I wondered if there were any little tips that might be useful?
Do I need to download a POI editor?
Old 06-07-2004, 5:52 PM   #6
6,875, Level: 19
Activity: 10.2%
Yes if you download POI editor then it does all the work for you, All you need to choose is which POI`s you want and it loads them to the SD card on your 2210 with the other POI`s that come woth TomTom
Old 06-07-2004, 7:17 PM   #7
roohster2's Avatar
7,601, Level: 20
Ok, which POIs do i need?
I downloaded the file and there are hundreds of things in there I dont want.
Whish is the camera data?
Old 06-07-2004, 8:01 PM   #8
6,875, Level: 19
Activity: 10.2%
The speed camera one should be at the top of the list "Pocket GPS_UK_SC", The rest are up to you whatever you want as POI`s when on your travels !
Highlight the one you want then click on +PDA at the top, Then you will get a box pop up and you select save which will add it to your PDA, Don`t forget to update it regularly by selecting autoupdate !
Old 06-07-2004, 8:11 PM   #9
shoehorn's Avatar
7,987, Level: 21
Nest time I must post faster!!
Old 07-07-2004, 6:05 AM   #10
roohster2's Avatar
7,601, Level: 20
Carlos, you're a star!
Job done.
Powered by
 Latest popular product prices
Nokia 1800
2 prices from
 £28.99 Click to show/hide the offers
Nokia 6303i classic
1 price
 £100.99 Click to show/hide the offers
Nokia 500
2 prices from
 £119.95 Click to show/hide the offers
Blackberry Curve 8520
3 prices from
 £147.99 Click to show/hide the offers
HTC Wildfire S
3 prices from
 £154.99 Click to show/hide the offers
Blackberry Curve 3G 9300
3 prices from
 £174.99 Click to show/hide the offers
Samsung Galaxy Ace GT-S5830
4 prices from
Blackberry Bold 9780
2 prices from
 £287.49 Click to show/hide the offers
 Updated February 12th at 10:30pm. Prices include delivery.
