Originally Posted by UCLdm I think Orange provide the best (and most cost-effective) UMA solution. Shame it's blocked by the likes of O2, but it works on Virgin Media and should work on the other mainsteam ISP's.. although i've heard something about BT blocking UMA in the past. |
Don't confuse UMA with a Femtocell. They are similar in concept but different in approach.
UMA uses your existing
WiFi connection to route mobile calls over. The connection is phone to WiFi.
A Femtocell is a dedicated device that plugs into your broadband connection (wired usually) and provides a GSM/3G signal. The connection is phone to mobile network signal.
Think of this as a repeater, the signal output is the same as a mobile mast would provide.
