Originally Posted by ekinlock my primary need is for a good internet browsing music playing phone so i have narrowed it down to the milestone or the desire, (screen ssize is important too) |
Internet browsing and music isn't that different between the two. I'm basing this on Android 2.01 on the Milestone Vs Android 2.1 on the Nexus, since the Desire hasn't been released. The browsers are the same, especially now Multitouch has been added to the Nexus.
The difference is in the text entry. Both have on-screen keyboards, the Milestone adds a physical QWERTY keyboard. For general surfing it makes sod-all difference, but for forum use, for email and for anything involving typing, the physical makes life easier.
That aside, there is nothing in it. The same applies to the music capabilities.
Originally Posted by ekinlock ...what i want to know if the android version 2.1 on desire with Sense is much better than the stock 2.0 on the milestone. |
Better is a subjective word... but it's certainly different and adds a visual flair missing from the stock Android UI. Not that Android itself doesn't look good, but the bells and whistles of Sense are certainly nice to live with.
But whether it's actually better, whether it helps you do anything is another matter.
And do bear in mind that there are numerous widgets and homescreens for 'normal' Android to add some of this flair and prettiness without needing Sense. So if the overall package of the Milestone suits you better, but you want the fancy stuff, it is possible.
Really, what you're comparing is the form factor, physical keyboard and visual flair. There wont be much else different to worry about.
I've deliberately left Blackberry out of this reply until now as, quite honestly, your priorities are BB's weaknesses. The browser on the latest BB OS is adequate. It's not bad by any means, but cannot compete with Android.
Music is very good though, in terms of simple navigation and sound quality.
I'd suggest Android would be the better choice of OS.
