Originally Posted by ninhydrin haha cheers rob I can see the usual going round in circles thing kicking in here
Porker I thought the HTC desire was already out? |
I'll give you my honest opinion, you can decide what to do with it...
Since Jan this year I've had the following phones:
iPhone 3GS
Google Nexus One
HTC HD2
Palm Pre
Motorola Milestone
BB 9700 (current weapon of choice)
The HTC HD2 is the best and most flexible media player. With CorePlayer installed especially there is almost nothing it wont play, it's very easy to use for media and the screen is huge and a good resolution.
However, unless you like a project and enjoy patching, hacking, registry tweaks and a lot of work like this, the HD2 is a frustrating device to live with otherwise. Insanely powerful and customisable, but Windows Mobile in every sense.
The Nexus One and Milestone are fairly even in this regards. The Nexus has the better screen, but washes out in sunlight. It also runs Android 2.1 which has a more advanced '3D' media gallery. But both are limited in their format support and have extremely basic video players.
The Palm Pre is great, but too small for video use. I'd discount this given your priorities, but would certainly consider it if it weren't for the video requirement as the web browsing is still very good.
The BB 9700 is the best
phone, in that it has awesome battery life (3x that of the others, easily), holds the best signal, has the best call clarity and the best messaging interface. But it's screen size is small and media playback limited. It's web browser is also limited, if fully functional.
The iPhone 3GS has limited format support. If iTunes / Quicktime doesn't play it, the iPhone doesn't. But it has the best media interface, easiest control and the sheer power of the iTunes library means there is an endless choice of media (TV, Films, Music, Podcasts etc) right at your finger tips. And there are plenty of free applications, such as Handbrake, that make it easy to convert media into a format it supports.
So in my opinion, the iPhone is the best option for you. The web browsing is also the best of the bunch. If you take the pain of converting media to the right format you'll get the best experience.
