Originally Posted by Pofadda Before trying the CalDAV option, I had a fairly successful 3-way sync (apart from some irritating but bearable Event duplications). All this took place with the Hotsync cable connecting to my Treo. Exchange Activesync is strictly wireless/phone, is it not? ...and my phone is Pay & Go with GSM connection. It can get a web connection if I really want it but would this entail 'ringing in' each time and fumbling with the (appalling) browser, perhaps? Could it be automated?
My apologies for my ignorance, but I have to start somewhere! |
Exchange ActiveSync (EAS) is indeed wireless/phone, but in this example it connects to the same source as your laptop is connecting to (Google) so you'll still have the fully meshed Sync.
It is all automated though, all behind the scenes in real time. It's essentially what coorporates use for mobile access to their Exchange hosted email. Google have just licensed the product and offered it as an alternative to IMAP/POP3, with the bonus of it including contacts and calendar.
I did a quick search before posting my original response to confirm your 650 supports EAS and found reference to a software update from 2007 that provided it, so I'm fairly confident you have the option you need. But to be sure, look in your email settings for the option to create/add a new account and look for the Exchange / Outlook option.
Assuming you have this option and it includes Contacts and Calendar, once setup everything in your Google account now will Sync to the device. It will then be kept in-sync in real time in the background, although some phones have the option to change this to a scheduled sync every x-minutes or hours. This is still automated though, so you wont have to go into the browser or manually start anything. It relies on your mail client doing all the work.
This will require a data connection of course and therefore, it would be wise to look at what data bundles your operator offers to minimise the cost. If this works as I would hope though, it will allow you to keep your current device which saves on cost overall.
