Originally Posted by RobM83 Sorry, but you can only do so if you own the website and hosting the image comes from. You can use free services like Photobucket and you can use the forums own image attaching option, available when you create the thread
No idea on the answer to your question though I'm afraid. I can only suggest trying your luck on eBay  |
cheers Rob, I know for next time now
there was nothing on ebay, even in completed auctions. i've found one website which values it a 400-600, but not sure how much I trust that, as it's the only place i've seen it
ah well, the hunt goes on!
