One thing to note - whilst a handset may have A-GPS (and use a tiny amount of data to help speed up getting a location fix) you don't have to use it. On my nokia e52, I have disabled A-GPS and just use standard GPS (no data used), as I have found that it gets a location fix really quickly anyway.
The other part to possible data useage relates to the maps. On Nokia phones, you can download maps in advance to the phone using a PC (e.g. mine has all the UK and France maps installed) so I never need to download data when I am out and about. If a phone uses google maps, it MUST download data as you go (and this can be a significant amount depending on useage) as maps are not stored on the phone. This also means that if you lose phone signal, you lose the ability to use google maps. For me, this is a real deal breaker with google maps as a Sat Nav device.
