PAC code and changing numbers.....
Old 25-02-2010, 1:24 AM   #1
3,274, Level: 13
Points: 3,274, Level: 13 Points: 3,274, Level: 13 Points: 3,274, Level: 13
Thanks: Gave 7, Got 5
Question PAC code and changing numbers.....
I have a PAYGO sim on orange and a CONTRACT sim on o2, i want to swap the numbers around. So im guessing i need to get the PAC code from both network providers?
Anyone give me any info on this as ive never done it before. Best/quickest way to go about doing this? best step to take first? how long does it take?
Old 25-02-2010, 9:56 AM   #2
4,027, Level: 14
Points: 4,027, Level: 14 Points: 4,027, Level: 14 Points: 4,027, Level: 14
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 46, Got 198
Using a PAC will cancel the contract and close the PAYG account. You cannot use a PAC to swap two numbers over.
Old 26-02-2010, 6:15 PM   #3
3,274, Level: 13
So i will lose atleast 1 number? seems stupid seen as im wanting to keep both just want them swapped. I dont see why it could not be done.
Old 26-02-2010, 7:07 PM   #4
RobM's Avatar
36,082, Level: 46
Points: 36,082, Level: 46 Points: 36,082, Level: 46 Points: 36,082, Level: 46
Activity: 35.8%
Activity: 35.8% Activity: 35.8% Activity: 35.8%
Thanks: Gave 854, Got 1,712
Are you planing on moving both numbers to a PAYG deal? Or were you planning on keeping a contract?
You could get two new SIM's, one for each network. Then transfer the O2 Contract to the new Orange PAYG. And the current Orange PAYG to the new O2 PAYG.
Networks are giving away free SIM's on their websites so it wont even cosgt anything.
Otherwise, it can't be done. May seem stupid, but it's fact.
Old 26-02-2010, 11:41 PM   #5
3,274, Level: 13
I want my orange paygo on my o2 contract and my o2 contract number on my paygo. can i not do that?
or what if i do this - get a pac code for my contract number, stick it on another o2 paygo sim and get o2 to give me any random number temp for my contract.
Then swap both numbers currently on paygo then when the number is on o2 paygo get the pac code and get it put onto my o2 contract??
Old 26-02-2010, 11:59 PM   #6
4,027, Level: 14
Activity: 0.7%
Using a PAC code cancels the account. This is the same on all networks. You cannot swap numbers like you want to do.
Old 27-02-2010, 3:24 AM   #7
3,274, Level: 13
So getting my pac code from my contract is impossible before my contract ends because its a sign of cancelling my contract?
Old 27-02-2010, 7:58 AM   #8
4,027, Level: 14
Activity: 0.7%
Almost, USING a PAC to port a number out closes the account and ends the contract. Indeed, as far as I know none of the providers will give you the code without paying off the remaining months.
Old 27-02-2010, 1:58 PM   #9
3,274, Level: 13
I dont beleive this, i paid a large amount of money for a very good easy to remember number on the paygo simcard. Just called o2 they say exactly what you said basically its impossible to change the number myself unless i cancel the contract. They can however give me a computer generated number. This is totally daft. The number on my contract right now is a good number too and i paid alot for that aswel, does this mean o2 now own this number and i will never get it back? if so surely thats a good enough reason to be able to cancel my contract?
Old 27-02-2010, 2:55 PM   #10
RobM's Avatar
36,082, Level: 46
Activity: 35.8%
No of course it doesn't mean that. As you've already been told above, you can change each number onto another SIM, you just cant change each of the two you have onto the opposite.
1) You could change the Orange PAYG onto another network PAYG, so you keep the number.
2) You can then change the O2 contract onto Orange PAYG, so you keep the number.
3) You can then change the number on the SIM you ported to in step 1 onto Orange PAYG.
Old 27-02-2010, 3:01 PM   #11
3,274, Level: 13
o2 at the CPW said im not allowed to use my own numbers in anyway. They insist i have to use there computer generated number if i want to change my number. Otherwise i have to cancel my contract then sign up a new contract with the pac code to the number i want to port over.
Old 27-02-2010, 3:12 PM   #12
RobM's Avatar
36,082, Level: 46
Activity: 35.8%
That may be CarPhoneWarehouses policy, it may be that specific salespersons lack of knowledge. But you can port a number to a new network SIM. That's the whole point of the PAC.
Instead of going through a third party, why don't you talk directly to the network? You'll be told the same thing about a direct swap, as it's simply not possible, but there are other options as has been said.
Old 27-02-2010, 3:19 PM   #13
3,274, Level: 13
Ok i will do, ive also emailed o2 at CPW with my concern and have mentioned i have 3 months left on my contract and i will cancel it just for the pure reason that i cannot use my own number. So if they want to lose a customer over this then so be it i will go elsewhere.
I should of been more clear basically my o2 contract is more important, so i want this unique number i have sitting on a orange paygo sim on my o2 contract. And if i can get the o2 contract number onto a paygo sim then thats a bonus as its a good number and is worth a little bit itself.
Old 27-02-2010, 3:54 PM   #14
RobM's Avatar
36,082, Level: 46
Activity: 35.8%
If you've only three months left, you could drop to the lowest tariff and pay it off, asking for your PAC at the same time. Then phone Orange and say you want to take that PAC from O2 and use it with one of their PAYG SIMs. You could also do this with any other network, it doesn't have to be Orange, the important thing is it's moving from the O2 contract to another network.
That keeps that number, cancels your O2 contract and allows you to start again. But you still have both numbers.
Then phone Orange and ask for the PAC for your favourite number on the current Orange PAYG SIM. Give this to O2 and start a new contract, with this PAC so you get the number.
This achieves what you want, in that you end up with both numbers saved and an O2 contract with your favourite number on it.
I can't personally think of a better way.
Old 27-02-2010, 4:02 PM   #15
3,274, Level: 13
Thanks, that does sound the only way.
The only downside is cancelling my contract will cost me 3 months line rental. Then taking a new contract out would put me at square 1. As in when i started my contract 3 years ago i was £40 a month after the years ive been up for renewal ive haggled them and im currently paying £15 a month down from the original £40 with extra add ons FREE O2 TO O2 FREE INTERNET..ect. I will be losing out so much just for the sake of using my own number. Too costly just to have a unique number.
Old 03-03-2010, 4:21 AM   #16
3,274, Level: 13
Responce i got from the email i sent to them....
Thank you for your email.
I'm sorry to advise you that the advisor you spoke to is correct. I can confirm you can not port any number into your Carphone Warehouse.
I'm sorry if this is not the response you were hoping for. If there where a way around this I would complete it for you as we do not want to lose you as a valued Carphone Warehouse customer.
If you have any other questions please reply to this email and
we'll be happy to help you
ARGHHHH its just a friggin number. which i desperatly need to change due to nuisance calls and texts. Im sure this infringes my human rights.
Old 03-03-2010, 7:42 AM   #17
4,027, Level: 14
Activity: 0.7%
If you ask to go through to their nuisance calls bureau then they can give you a change of number (you still won't be able to port a number in or swap numbers over).
Powered by
 Latest popular product prices
Nokia 1800
2 prices from
 £28.99 Click to show/hide the offers
Nokia 6303i classic
1 price
 £100.99 Click to show/hide the offers
Nokia 500
2 prices from
 £119.95 Click to show/hide the offers
Blackberry Curve 8520
3 prices from
 £147.99 Click to show/hide the offers
HTC Wildfire S
3 prices from
 £154.99 Click to show/hide the offers
Blackberry Curve 3G 9300
3 prices from
 £174.99 Click to show/hide the offers
Samsung Galaxy Ace GT-S5830
4 prices from
Blackberry Bold 9780
2 prices from
 £287.49 Click to show/hide the offers
 Updated February 13th at 1:30am. Prices include delivery.
