I have the omnia hd (i8910). Out of the box, the phone is pretty awful. You need to spend time on samsungi8910omnia.com and install a different rom to bring it up to speed. Even then, though, there are many things left to be desired. Samsung's support for the phone is virtually non-existant, so you wont get those nokia-esque frequent updates.
Hardware-wise, it is quite simply the best phone on the market, even though frames are dropped when recording 720p. Software-wise, it isnt. If you are familiar with symbian, so know where to look for apps etc, then you may be ok, but you cannot rely on any app-store, quite simply because there isnt one for this phone. I got mine from ebay (basically swapped for my n97), and my contract is only 12 months. If you are entering into an 18mth+ contract, I'd look elsewhere, as lack of support for the phone means it will be obsolete fairly soon (the phone has already been out for 6 months on Orange).
There is, however, a big price difference between the 3gs and the omnia hd, so its not really fair to compare. I'd be tempted to wait for the motorola milestone which is due fairly soon - maybe even next month (its out in germany already). The Satio is a similar phone, but the bigger oled capacitive screen of the omnia edges it for me.
