Installed sim card reader - 2 sim cards & 2 handsets now not working – help, please
Hello,
I bought a SIM Card Reader from a co on eBay UK. It came with a driver CD but didn’t state compatible with Vista, and it didn’t install properly. I downloaded another driver from the Prolific website, which installed OK.
So, I plug my o2 SIM into the Reader and plug it into a USB port on my Desktop. A Windows pop-up ‘Searching for Driver’ appears. The pop-up then states Driver is located. That’s it. Nothing happened at all. I unplugged the Reader & plugged it back in. Nothing. There seems no way to get it to work. I e.mail the Seller, who responds with a link to another Driver. I download it and execute. Same result.
No big deal, it only cost a few £££s, so I’ll chuck it.
HOWEVER….. I put the SIM back in my Nokia 6822a handset (unlocked, & owned for 2 years, no probs), switch on, & enter PIN, which is accepted. I get an onscreen message ‘Phone restricted’. I click the ‘undo’ button and it asks ‘Enter restriction code’. I try 12345 and a PUK code from o2. Neither work.
I try the SIM in another handset (Nokia 6800), and get the message ‘SIM card registration failed.
I try another SIM card in my original handset, and this won’t work, either.
Can anyone suggest what has happened here? Both handsets & SIMs OK and unlocked. Working until last night.
Also, how do I resolve it? I need my SIMs restored and my handsets working.
Many thanks.
