Originally Posted by Kazman Uhm, have we all forgotten about the Samsung i8910 HD?
In my humble opinion, I think it is a much better option than either the N97 or iPhone 3GS.
As long as people can accept Samsung as a credible alternative and get around "it has to be a nokia or an iphone" mentality, then the Samsung i8910 HD could well be the perfect device.
I did, and bought one as a result! I have used a very large number of phones in the past, and the i8910 HD is probably the closest to phone perfection I have come across. |
Yes, I too have been looking at this phone with some fascination. I posted the following about the Samsung Omnia HD in another forum:
"I think the Samsung Omnia HD i8910 is definitely worth a look.
Check out a good in depth review with comparisons -
http://my-symbian.com/s60v3/review_omnia_hd.php
Advantages:
- The most powerful CPU of all Symbian OS phones up to date: OMAP3430 with ARM Cortex A8 core running at 600 MHz.
- PowerVR SGX530 GPU (hardware graphics accceleration) delivering OpenGL ES 2.0 support and performance.
- 3x performance boost (and 4x in multimedia applications) compared to other Symbian OS phones based on older processors.
- 256 MB of operating memory (RAM) and almost 140 MB free, compared to 128 MB (and 40-50 MB free) on other S60 5th Edition phones.
- Built-in 8 or 16 GB of storage memory + microSD slot for cards up to 32 GB.
- 8 Megapixel camera: fast operation, high sensitivity up to ISO 1600 with low noise up to ISO 800.
- HD 720p (1280x720 pixel) high quality (with virtually no compression artefacts) video recording.
- Marvellous AMOLED capacitive display.
- With its 3.7" physical size, the screen is perfect for multimedia playback and navigation, and makes using the device easier as all UI elements (buttons, keys of the virtual keyboard, sliders, etc.) are bigger, i.e. easier to hit
build quality is very decent, at least there's nothing to complain about after few weeks of use.
- All connectivity options are included, and some of them exceed current "standards", like e.g. HSDPA 7.2 Mbps / HSUPA 5.7 Mbps
- GPS receiver seems to be considerably faster and more sensitive than on other S60 5th Edition phones; no problems with obtaining the fix almost instantly even indoors. The GPS+ application can provide AGPS data for the entire week.
- Battery life, despite the powerful processor and large screen, does not seem to be any worse than on other high-end S60 devices.
Disadvantages:
- HD video recording slightly below actual "HD ready specification" due to frame rate within 20-21 fps range, which in some circumstances results in blurred/unsmooth motion.
- No HDMI (or any other) connector to output HD video via cable to a HD TV.
- Low quality of audio (AMR 8-bit) and some issues with it in video recordings.
- The touch screen is "too sensitive" on its edges which often results in accidental touches (e.g. when you grab the phone) being recognized as taps."
