transfering contacts from sim to sim
Old 30-05-2009, 10:16 AM   #1
6,151, Level: 18
Points: 6,151, Level: 18 Points: 6,151, Level: 18 Points: 6,151, Level: 18
Thanks: Gave 62, Got 21
what is the best way
i have a veiwty on 3, and moving to a touch pro 2 on voda or t mobile
my contacts have multi numbers and email address
whats the bext options
as the phone im getting is windows mobile, it will sync easy enough with the pc, so what is the best format to try to store them in on the pc
thanks for any help
Old 30-05-2009, 1:05 PM   #2
RobM's Avatar
36,082, Level: 46
Points: 36,082, Level: 46 Points: 36,082, Level: 46 Points: 36,082, Level: 46
Activity: 35.8%
Activity: 35.8% Activity: 35.8% Activity: 35.8%
Thanks: Gave 854, Got 1,712
Re: transfering contacts from sim to sim
You could try using the LG PC Suite software. This should allow you to synchronise the PC and Phone, so you can have your contacts stored in Outlook ready for the new TP2
pointyone (30-05-2009)
Old 01-06-2009, 1:06 PM   #3
6,151, Level: 18
having major problems with the lg pc suite, it will not allow me into contacts messages etc etc , and when i try o sync with out look if out look is running it will not sync, if its not running it will synce but no info is there
are there any other ways of getting my contact info from my sim
Old 01-06-2009, 1:21 PM   #4
RobM's Avatar
36,082, Level: 46
Activity: 35.8%
Try Zyb.com
It's a free Over-The-Air synchronisation service and it claims to support both the Viewty and the TP2 so you should be laughing. I use it as an online backup of my calendar and contacts just in case I lose my phone (or at least I did until I got the HTC Magic and now use Googlemail instead). Anyway... sign up on the website, stick in your phone details and phone number and it will send the settings to your phone. Follow the prompts and enter the pin when prompted and you can sync your contacts to Zyb.com
Then when you get the TP2, follow the same process and they will sync down to the TP2.
It's a free service, but it does transmit data via your network operator so you may get charged a few pence for data.
pointyone (01-06-2009)
Old 01-06-2009, 1:31 PM   #5
6,151, Level: 18
thanks worked a treat
Old 01-06-2009, 2:27 PM   #6
RobM's Avatar
36,082, Level: 46
Activity: 35.8%
Awesome
It's handy to keep active as a backup too. If your phone gets stolen you don't have to worry about losing all the contacts you've built up over the years. Just Sync every now and again and you're all backed up
Old 01-06-2009, 4:51 PM   #7
6,151, Level: 18
sorry it didnt work and all i keep getting now is connection failed
i have handed over my pac number and my new phone arrives tomorrow
any other way of doing this before my sim locks up and i loose all my contacts info
thanks for any help
Old 01-06-2009, 11:17 PM   #8
6,151, Level: 18
getting desperate now
cant backup using pc suite as i am on vista, tried all the work arounds on the net but none work
tried to sync them to ZYB but all i get is is snycro failed server not available
i have my new phone on the way and if they shut my sim off i will loose it all
please any more help anyone
Old 02-06-2009, 1:17 PM   #9
1,767, Level: 9
Points: 1,767, Level: 9 Points: 1,767, Level: 9 Points: 1,767, Level: 9
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Whenever I've needed to transfer contacts from SIM to SIM, I just put the old one in the phone and transferred them to the phones internal memory. Then, put the new SIM in the phone and transfer them back from the phone memory to the new SIM. I've never had the old SIM lock up totally after it was deactivated. Obviously it can't make calls but I could still access the messages and contacts on it. I assume this is the case for all sims. Not sure of the process of doing the transfer on windows mobile (I have nokia phones) but I think this should work fine.
On another note (again this is a wild shot in the dark and may be totally wrong for your viewty), I can only sync contacts with outlook if they are stored in the phone memory and not on the sim. Thats why I now keep the contacts in the phone memory and sync to outlook for backup purposes.
Hope that helps a bit,
Burry1
Old 02-06-2009, 2:53 PM   #10
6,151, Level: 18
panic over
got the touch pro 2 today, its unlocked so put in my 3 sim copied over contacts to the phone then took the sim out, my number ports over tomorrow
Powered by
 Latest popular product prices
Nokia 1800
2 prices from
 £28.99 Click to show/hide the offers
Nokia 6303i classic
1 price
 £100.99 Click to show/hide the offers
Nokia 500
2 prices from
 £119.95 Click to show/hide the offers
Blackberry Curve 8520
3 prices from
 £147.99 Click to show/hide the offers
HTC Wildfire S
3 prices from
 £154.99 Click to show/hide the offers
Blackberry Curve 3G 9300
3 prices from
 £174.99 Click to show/hide the offers
Samsung Galaxy Ace GT-S5830
4 prices from
Blackberry Bold 9780
2 prices from
 £287.49 Click to show/hide the offers
 Updated February 12th at 8:30pm. Prices include delivery.
