What does flicking the sixaxis do?
Old 16-06-2008, 11:55 AM   #1
2,311, Level: 11
Points: 2,311, Level: 11 Points: 2,311, Level: 11 Points: 2,311, Level: 11
Thanks: Gave 57, Got 14
If your say lying on the floor and invisible, if you flick the joystick (hold the controller with say your left hand, and flick it as though you are throwing a frisbee), you become visible again and it's obviously doing something.
But I cant work out what?
Anyone sussed it out please?
thanks
Old 16-06-2008, 11:57 AM   #2
5,759, Level: 18
Points: 5,759, Level: 18 Points: 5,759, Level: 18 Points: 5,759, Level: 18
Thanks: Gave 84, Got 28
Re: What does flicking the sixaxis do?
If you shake the sixaxis whilst in camo mode it actually resets the camo back to normal so maybe thats thats whats happening with you.
Ojustabo (16-06-2008)
Old 16-06-2008, 12:30 PM   #3
2,311, Level: 11
Yep that's exactly what's happening
Just wondered whether there was any further point to this though (is the camo reset the result of something else happening). Seems an odd feature to program in.
Old 16-06-2008, 2:53 PM   #4
11,201, Level: 25
Points: 11,201, Level: 25 Points: 11,201, Level: 25 Points: 11,201, Level: 25
Thanks: Gave 85, Got 223
It's to reset the camo when you want it to... if you don't like running around in your snow coloured camo you can flick it and it reverts to normal... Although, I can't seem to get this to work
Oh, also, flick it when you're talking to Rose on the codec...
Old 16-06-2008, 5:36 PM   #5
Hubba-EX's Avatar
12,283, Level: 26
Points: 12,283, Level: 26 Points: 12,283, Level: 26 Points: 12,283, Level: 26
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 222, Got 225
Heres one I heard in the 1up yours podcast with Ryan Peyton,
When in codec with Rose, shake the controller about and her boobies shake as well
