Game gets stuck at very first screen!!!!
Old 15-06-2008, 8:33 PM   #1
nick270881's Avatar
6,902, Level: 19
Points: 6,902, Level: 19 Points: 6,902, Level: 19 Points: 6,902, Level: 19
Thanks: Gave 11, Got 62
Well I finally put MGS4 into my PS3 tonight to play and it will not go past the first screen where you have to press x (This game saves data automatically, do not turn off when the HDD access light flashes)
Anyone else had this problem?? It will not respond to presses of the x (I have tried all others aswell) all I can do is exit to the XMB and try again but the same happens (btw I am using a UK game on a US PSŁ if that makes any difference)
Might have to pop down to game tomorrow and see if they can swap it
Old 16-06-2008, 12:48 PM   #2
2,867, Level: 12
Points: 2,867, Level: 12 Points: 2,867, Level: 12 Points: 2,867, Level: 12
Thanks: Gave 1, Got 4
Re: Game gets stuck at very first screen!!!!
Have you tried re-assigning the PS3 controller to controller '1'?
Old 16-06-2008, 2:14 PM   #3
nick270881's Avatar
6,902, Level: 19
Yep, Tried that and still no good. BUT..............Fixed now!!...........I had the dongle for my rock band guitar in one of the USB slots and for some reason when I took it out it worked, Strange that this is the only game it does it with though!!??
Old 16-06-2008, 2:34 PM   #4
2,867, Level: 12
That's good. I have a USB IR dongle plugged in and if I switch on the PS3 using the controller I have to re-assign the controller to '1' otherwise I have the same issue.
Old 16-06-2008, 2:50 PM   #5
CH_Peter's Avatar
5,733, Level: 17
Points: 5,733, Level: 17 Points: 5,733, Level: 17 Points: 5,733, Level: 17
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 81, Got 215
Had the same problem and can confirm it was the GH Guitar dongle. Took it out, no problem.
