how long does the game take to complete?
Old 13-06-2008, 7:11 PM   #1
shoestring25's Avatar
12,839, Level: 27
Points: 12,839, Level: 27 Points: 12,839, Level: 27 Points: 12,839, Level: 27
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 26, Got 81
im wondering how long the game takes to complete? how many acts are there
Old 13-06-2008, 7:34 PM   #2
DaddyDee's Avatar
6,911, Level: 19
Points: 6,911, Level: 19 Points: 6,911, Level: 19 Points: 6,911, Level: 19
Thanks: Gave 290, Got 91
Re: how long does the game take to complete?
No idea how long to complete, but according to the game guide there are 5 acts.
Old 13-06-2008, 8:06 PM   #3
Hubba-EX's Avatar
12,283, Level: 26
Points: 12,283, Level: 26 Points: 12,283, Level: 26 Points: 12,283, Level: 26
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 222, Got 225
Depends how you play, I have only completed Act 1 and have already clocked 5 hours.
I completed Heavenly Sword in about 6 hours.
Also Metal Gear is the type of game you will want to play many times over.
Old 13-06-2008, 8:32 PM   #4
harrisuk's Avatar
21,025, Level: 35
Points: 21,025, Level: 35 Points: 21,025, Level: 35 Points: 21,025, Level: 35
Thanks: Gave 2, Got 60
Well I am on act 4 and it took me 13 hours to get there on normal I have been pretty comprehensive. I think it will be around 20 hours if you do it properly.
Old 13-06-2008, 8:35 PM   #5
5,171, Level: 17
Points: 5,171, Level: 17 Points: 5,171, Level: 17 Points: 5,171, Level: 17
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 913, Got 419
Once you complete the game and start again, are you able to then skip the cut scenes?
Not that i want to 1st time around, but 2nd time around you'd want to get on with it.
Old 13-06-2008, 10:14 PM   #6
5,107, Level: 16
Points: 5,107, Level: 16 Points: 5,107, Level: 16 Points: 5,107, Level: 16
Thanks: Gave 4, Got 19
Yes.
Old 13-06-2008, 11:10 PM   #7
4,373, Level: 15
Points: 4,373, Level: 15 Points: 4,373, Level: 15 Points: 4,373, Level: 15
Thanks: Gave 30, Got 17
i played on normal solid first go and it took me 20 hours 23mins and that included watching all cut scenes
Old 14-06-2008, 12:07 AM   #8
Conspicuous Member
31,812, Level: 43
Points: 31,812, Level: 43 Points: 31,812, Level: 43 Points: 31,812, Level: 43
Activity: 8.4%
Activity: 8.4% Activity: 8.4% Activity: 8.4%
Thanks: Gave 114, Got 428
I completed the whole game on naked normal in 15 hours.
Old 14-06-2008, 12:15 AM   #9
2,311, Level: 11
Points: 2,311, Level: 11 Points: 2,311, Level: 11 Points: 2,311, Level: 11
Thanks: Gave 57, Got 14
I'm on the default solid normal setting.
It took me two hours from the start of act 1 (after the intro scenes) to get to the very first destination. Never died so much
At this rate it should keep me occupied for years
I'm beginning to get the hang of it now though
Old 14-06-2008, 6:08 AM   #10
5,171, Level: 17
Activity: 1.7%
Hehe, same as me. I'm the worst stealth person in the world
Old 14-06-2008, 3:07 PM   #11
Conspicuous Member
21,887, Level: 35
Points: 21,887, Level: 35 Points: 21,887, Level: 35 Points: 21,887, Level: 35
Activity: 12.8%
Activity: 12.8% Activity: 12.8% Activity: 12.8%
Thanks: Gave 190, Got 733
Just finished on Naked Normal - took about 20 hours without skipping any cutscenes...
Old 14-06-2008, 8:25 PM   #12
m1ket's Avatar
12,765, Level: 27
Points: 12,765, Level: 27 Points: 12,765, Level: 27 Points: 12,765, Level: 27
Thanks: Gave 267, Got 265
9hrs after act 2
Old 23-06-2008, 4:52 PM   #13
mook1979's Avatar
2,824, Level: 12
Points: 2,824, Level: 12 Points: 2,824, Level: 12 Points: 2,824, Level: 12
Thanks: Gave 7, Got 1
I completed the first two acts in just under 10 hours.
Old 23-06-2008, 6:39 PM   #14
8,834, Level: 22
Points: 8,834, Level: 22 Points: 8,834, Level: 22 Points: 8,834, Level: 22
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 996, Got 484
It can be done in less than five hours....took me 20 Hours 22 minutes on the default difficulty.
Old 23-06-2008, 7:06 PM   #15
10,460, Level: 24
Points: 10,460, Level: 24 Points: 10,460, Level: 24 Points: 10,460, Level: 24
Activity: 12.8%
Thanks: Gave 89, Got 262
Once you've completed it on a normal difficulty play it again with the difficulty bumped up to maximum.
It feel like a very different game with the enemies far more sensitive to your presence/movements,and there is a much wider variety of weapons/mods available on the second play
Old 25-06-2008, 10:46 AM   #16
10,551, Level: 24
Points: 10,551, Level: 24 Points: 10,551, Level: 24 Points: 10,551, Level: 24
Thanks: Gave 193, Got 265
I haven't been back to this since the day I loaded it. It took so long to get going that I had a few minutes of actual play, got killed and switched off because I had to rebuild my gaming PC and the new HDD had arrived. I haven't been back to it because, in my mind, the length of time it took with the cutscenes didn't make it very engaging so I've been playing Assassins Creed on my revitalised gaming rig. I do mean to play MGS but it isn't the most inspiring game as far as grabbing your interest with the gameplay at the start. I assume it becomes more engaging as it progresses.
Old 25-06-2008, 10:56 AM   #17
catisfit's Avatar
10,619, Level: 24
Points: 10,619, Level: 24 Points: 10,619, Level: 24 Points: 10,619, Level: 24
Thanks: Gave 349, Got 452
Hideo Kojima has always been criticised (unfairly in my view) for too many cutscenes and not enough gameplay, so at the start of MGS4 he keeps taking control away from the player - it's a thinly-veiled dig at his critics
Once you get around the first corner the game gets going properly
Old 25-06-2008, 11:39 AM   #18
harrisuk's Avatar
21,025, Level: 35
I got to near the end of the final act within 20 hours on normal within the first few days of owning it but I have not gone back to complete it yet. I am not that convinced of the replay value of it, also much of the gameplay length is actually cut scenes.
Old 25-06-2008, 12:03 PM   #19
catisfit's Avatar
10,619, Level: 24
Apparently somebody ripped all the videos and codecs out of the game and put them into a video - they total 9.5 hours
Old 25-06-2008, 2:17 PM   #20
Conspicuous Member
20,843, Level: 35
Points: 20,843, Level: 35 Points: 20,843, Level: 35 Points: 20,843, Level: 35
Activity: 5.1%
Activity: 5.1% Activity: 5.1% Activity: 5.1%
Thanks: Gave 952, Got 1,365
That depends on how much of a completionist you are. I finished it last friday and haven't played it again yet, but I definately will play through again at some point to try to gain some of the different awards. I played through Uncharted about 3 months after the 1st completion and still enjoyed it. I am looking forward to playing MGS4 again but want to leave it a while so I don't remember every little detail.
Old 29-06-2008, 8:09 AM   #21
3,202, Level: 13
Points: 3,202, Level: 13 Points: 3,202, Level: 13 Points: 3,202, Level: 13
Thanks: Gave 19, Got 29
Took me 16 hours on my first playthrough on Solid Normal but that includes watching all cut scenes
Old 30-06-2008, 7:58 PM   #22
Pritz's Avatar
3,659, Level: 14
Points: 3,659, Level: 14 Points: 3,659, Level: 14 Points: 3,659, Level: 14
Thanks: Gave 9, Got 2
First go, I took my time, enjoyed the sights etc and clocked 24 hours on solid normal...long but so worth every second
Old 09-07-2008, 9:03 PM   #23
Mark 1971x's Avatar
2,622, Level: 11
Points: 2,622, Level: 11 Points: 2,622, Level: 11 Points: 2,622, Level: 11
Thanks: Gave 9, Got 11
Well then get on gears and take Ram out on insane.
Old 11-07-2008, 9:25 AM   #24
8,344, Level: 21
Points: 8,344, Level: 21 Points: 8,344, Level: 21 Points: 8,344, Level: 21
Thanks: Gave 101, Got 194
is there a difference between liduid normal and solid normal? i cant find the answer anywhere?
Old 17-07-2008, 9:15 PM   #25
BIONIC MAN's Avatar
9,692, Level: 23
Points: 9,692, Level: 23 Points: 9,692, Level: 23 Points: 9,692, Level: 23
Thanks: Gave 0, Got 4
Will I'am now starting Act 5 and been playing for over 17 hours , Mate of mine finished his in about 21 hours
Have to say I will be playing again
