Does Metal gear solid 3 subsistence work on ps3?
Old 27-05-2007, 8:33 PM   #1
Man_pete
Posts: n/a
I have a NTSC ps3 and I have yet to play MGS3, I was wondering if anybody knew if MGS3(NTSC)works on the PS3 system or if there are any problems with it??
don't want to spend my money on the game if it dosen't work
M pete
Old 27-05-2007, 11:22 PM   #2
Bushido's Avatar
6,187, Level: 18
Points: 6,187, Level: 18 Points: 6,187, Level: 18 Points: 6,187, Level: 18
Thanks: Gave 74, Got 58
Re: Does Metal gear solid 3 subsistence work on ps3?
Id like to know this one as well...the game does not appear on the BC list.
Old 28-05-2007, 1:18 AM   #3
Mugs
Posts: n/a
i have the ntsc j subsistence and it works fine on my ps3......hope that helps.
Old 28-05-2007, 9:24 AM   #4
7,704, Level: 20
Points: 7,704, Level: 20 Points: 7,704, Level: 20 Points: 7,704, Level: 20
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 117, Got 179
Yea it works, whacked it in yesterday to carry on playing, looks nice with Smoothing on, maybe a little too smooth, will try it turned off today I think.
Old 28-05-2007, 9:54 AM   #5
44,497, Level: 51
Points: 44,497, Level: 51 Points: 44,497, Level: 51 Points: 44,497, Level: 51
Thanks: Gave 108, Got 1,460
Whilst I haven't played it yet it does certainly boot up fine. I'm sure it's been on the US backward compatibility list from the beginning though. I seem to recall checking when people mentioned a while back that the PAL one wouldn't work.
Old 28-05-2007, 10:23 AM   #6
littlelio
Posts: n/a
I guess it works on US PS3.
By the way, generally MGS3 works fine. But in some scene such as the fight with the Fury, it is terribly slow due to all the flame across the screen...
Old 29-05-2007, 7:11 AM   #7
Bushido's Avatar
6,187, Level: 18
Just to let you know I bought the PAL copy of MGS3 yesterday and it works fine. Looks nice too.
Old 29-05-2007, 8:39 AM   #8
Eminent Member
Tejstar's Avatar
126,891, Level: 86
Points: 126,891, Level: 86 Points: 126,891, Level: 86 Points: 126,891, Level: 86
Thanks: Gave 408, Got 993
Yep had no problems (so far ) with my PAL copy either.
Old 13-06-2008, 12:49 PM   #9
harrisuk's Avatar
21,025, Level: 35
Points: 21,025, Level: 35 Points: 21,025, Level: 35 Points: 21,025, Level: 35
Thanks: Gave 2, Got 60
This is an intersting thread as I am thinking of replaying MGS3 when I finish mgs4.
Can anyone confirm that Subistance works on the pal 60gb ps3, its on the backwards complatability list with "serious issues"
Snake eater dosnt seem to be on their at all but my copy works.
Also anyone know how to get hold of game saves, I have the transfer tool but I seem to have lost the memory card with my mgs3 game saves on it
Old 13-06-2008, 1:24 PM   #10
6,383, Level: 19
Points: 6,383, Level: 19 Points: 6,383, Level: 19 Points: 6,383, Level: 19
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 1,030, Got 343
Do not know how relevant this is but my US Copy works perfectly on my US 60Gb Machine
Old 13-06-2008, 1:52 PM   #11
11,048, Level: 25
Points: 11,048, Level: 25 Points: 11,048, Level: 25 Points: 11,048, Level: 25
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
Thanks: Gave 271, Got 294
Is that the original game or the re-released platinum?
Seems that there are multiple versions of many games and some are compatible, some aren't.
Was thinking of getting 2&3 myself ... have just got MGS4 so would I be better to play the other two first or just play 4 and then go back to 2 and 3?
Old 13-06-2008, 2:48 PM   #12
4,619, Level: 16
Points: 4,619, Level: 16 Points: 4,619, Level: 16 Points: 4,619, Level: 16
Thanks: Gave 53, Got 95
M pete
my USA Metal Gear Solid: The Essential Collections came today. £17.50 from VG+ :D
just tried all 3 MGS games and they all work perfect on my NTSC PS3 - so yeah no probs. i still gotta play thru 3, then im hitting the daddy that is 4
Stinja (13-06-2008)
Old 13-06-2008, 3:02 PM   #13
20,085, Level: 34
Points: 20,085, Level: 34 Points: 20,085, Level: 34 Points: 20,085, Level: 34
Activity: 13.9%
Activity: 13.9% Activity: 13.9% Activity: 13.9%
Thanks: Gave 323, Got 685
Yeah i saw that, had my finger hovering over the "buy" button when the thought was "will it work on my USA 60GB?". Be great if it does - i'd love to have a crack at MGS1 again.
Old 13-06-2008, 5:37 PM   #14
harrisuk's Avatar
21,025, Level: 35
I am assuming you have a ntsc ps3 then as ntsc ps2 games dont work on the pal console...
Old 13-06-2008, 7:55 PM   #15
Eminent Member
66,371, Level: 62
Points: 66,371, Level: 62 Points: 66,371, Level: 62 Points: 66,371, Level: 62
Activity: 31.1%
Activity: 31.1% Activity: 31.1% Activity: 31.1%
Thanks: Gave 1,481, Got 1,662
I think that I may have to play through all 4 MGS games after my MGS4 run through.
I'll need to get them all again but at least I can play them through in their proper order MGS3, MGS1, MGS2, MGS4.
Old 13-06-2008, 10:37 PM   #16
harrisuk's Avatar
21,025, Level: 35
I am going to try twin snakes on the cube instead of the original ps1 mgs. Its meant to be much better using the mgs2 engine but basically the same mgs story....
I already have mgs 3 snake eater and will probably replay mgs 2 substance on the xbox.
I was thinking of gettings mgs3 subsistence hence question if the pal version runs ok on the ps3 60gb back compat
Old 14-06-2008, 12:08 AM   #17
Eminent Member
66,371, Level: 62
Activity: 31.1%
Yeah, good idea with Twin Snakes, may get that and play it on the Wii.
MGS3 Subsistance is supposed to be much better than Snake Eater (mainly due to the 3rd person camera that you can move around the player, like MGS4 I guss) so I may get that. I never bothered with MGS3 for some strange reason so I am looking forward to that one. I used to have Sons of Liberty, but my brother has it now so I may well borrow that back off him.
Old 17-06-2008, 2:46 PM   #18
11,048, Level: 25
Activity: 0.9%
Right - so I can pick up the PS2 MGS3 and it will work on my 60gig PAL PS3?
Now - does the original MGS for PS1 work on PS3?
Old 17-06-2008, 3:10 PM   #19
6,288, Level: 18
Points: 6,288, Level: 18 Points: 6,288, Level: 18 Points: 6,288, Level: 18
Activity: 15.5%
Activity: 15.5% Activity: 15.5% Activity: 15.5%
Thanks: Gave 128, Got 272
If sony and konami wanted to be really clever they should release MGS1 on the PSN asap.
Old 17-06-2008, 3:10 PM   #20
7,704, Level: 20
Activity: 2.4%
Yep, on both accounts.
gavan (17-06-2008)
Old 17-06-2008, 3:11 PM   #21
7,704, Level: 20
Activity: 2.4%
I think it's coming soon, it is already on the Japanese store.
There is rumor of it going to Xbox Live Arcade aswell.
Old 17-06-2008, 3:59 PM   #22
6,288, Level: 18
Activity: 15.5%
Good luck getting hold of it for a decent price.
Just had a quick look on ebay and Twin Snakes is going for nearly £40 in some cases which is more than i paid for MGS4.
http://search.ebay.co.uk/search/sear...=32%26fsoo%3D2
Old 17-06-2008, 4:28 PM   #23
44,497, Level: 51
I've still got the US version which I bought when it was released. I don't remember how much I paid for it but it was no where near that. I might have to go back to it.
Old 18-06-2008, 10:36 AM   #24
6,288, Level: 18
Activity: 15.5%
I see amazon market place have twin snakes going fairly cheap.
http://www.amazon.co.uk/gp/offer-lis...3785199&sr=8-1
Old 18-06-2008, 6:58 PM   #25
3,853, Level: 14
Points: 3,853, Level: 14 Points: 3,853, Level: 14 Points: 3,853, Level: 14
Thanks: Gave 109, Got 74
Will this work on the Jap PS3???!!
Old 19-06-2008, 9:20 PM   #26
44,497, Level: 51
No it won't as all PS2 games are region locked. The fact that both Japanese and US PS2's are NTSC format doesn't matter.
