01-02-2009, 10:43 AM
#1
Thanks: Gave 2, Got 3
My Home Entertainment System Project
After going round to my friend’s house that has a post of his project on this forum I had to do something with my living room, to say that I was impressed with his new home entertainment system was an understatement. See his thread thefathacker
My living room is completely different although I took most of, or may I say all his ideas I suppose that’s why we have these forums and yes I am very new to all this.
Now to start I had to knock down a fireplace that was built for me about 7 years ago by a bricklayer that used 4 bags of cement to build it!! Yes I know I would have been most likely able to build a new house with that amount of cement!!, so as you can quite imagine it took some hard graft to knock it down!!
Now I was given advice from my good friend thefathacker to knock down my chimney breast but after the first palaver with the fireplace I really couldn't be bothered as this was only going to be a small project!!, yes I wish I had now but I suppose hindsight got the better of me, never mind.
After all the bricks were clear I got a friend round who is a joiner and together we planned and drew out what is hopefully going to be a fantastic looking Home Entertainment System.
I've gone with the Samsung LE40A656A LCD T.V I looked at a few different TV’s but I really liked this one and it's got good reviews, the bracket I bought will be too wide making the TV stick out to much then making the joiner bring out the floating wall to far, so I need to shop around for a good bracket that has a swivel on it that’s not to wide (thick) any ideas links are most welcome thank you.
The rest of the cables etc have all arrived and also I've installed new speaker wire to the rear speakers in the rear corners of the living room.
I've gone with the same Amp as my friend the Denon AVR1909 which I got for a bargain of £270.00 brand new.
Well I’m up to the stage now of getting in all the cables sorting all the electrics for back lights etc now as you can see from the photos still a long way to go but I’m really looking forward to the finished article.
I will be having cupboards either side of the chimney breast to store a PC playstation 3 and any other bits and pieces, there will be one remote control a Logitech's Harmony 895 universal to do all.
Any ideas whilst I am constructing my project would be most welcome.
Thanks for looking at my thread.
01-02-2009, 11:39 AM
#2
Re: My Home Entertainment System Project
So out with the old fireplace..
01-02-2009, 11:42 AM
#3
And finally it's down.. Thank god.. That was hard work!! Idiot of a bricky!!!
And ready for the work to commence..
01-02-2009, 11:47 AM
#4
Thanks: Gave 69, Got 94
good stuff, il be watching this!
Sony KDL40W2000, Onkyo TXSR875B, SONY PS3, Xbox 360, Sky HD, Wii, B&W 603's, AE 107C, and some cheaper speakers to compleate the 7.1 Speaker setup.
01-02-2009, 11:48 AM
#5
And now for stage 1 of the woodwork to be done.
01-02-2009, 11:51 AM
#6
Thanks Grangey..
01-02-2009, 11:53 AM
#7
The start of stage 2, side walls..
01-02-2009, 11:56 AM
#8
And this is where Im up to today..May take a bit of time as the Joiner can only come round on Saturdays..
01-02-2009, 2:23 PM
#9
Thanks: Gave 28, Got 30
The change of height of your TV is going to take some getting used to mate.
What made you want it so high?
02-02-2009, 3:17 PM
#10
Yeah ur right Nuwidol it proberly will take some gettin used to, didn't want it too low but that's why I put the TV up today I've got a 5 days to change my mind when the joiner comes back, it will only take 10 mins to lower it.
Thanks for the advice buddy.
02-02-2009, 4:46 PM
#11
Thanks: Gave 1, Got 2
Was a nice fireplace! Liking the look of the new floating wall, cant wait to see the finished article. What are you doing speakers wise?
02-02-2009, 6:23 PM
#12
Hi acgwilliam...I've got three 75watt speaker manufactured by Adastra which quite frankly I've never heard of but they had great reviews so hopefully they will be O.k, they will be mounted by the side of the T.V.
I have two wall mounted speakers made by Panasonic for the rear above the couch.
Thanks for looking.
Front Speakers x 3
Rear Speaker
02-02-2009, 6:59 PM
#13
Thanks: Gave 16, Got 3
Looking good Larry - looking good and there is deffo no turning back now.
By the way, you should credit Groove for the floating wall concept. Every floating walll built on here in the last 18 months has been based on his me thinks.
I am watching with interest!
02-02-2009, 7:08 PM
#14
Thanks: Gave 37, Got 138
Great job so far!
This is more suited in the DIY projects section of the forum though.
AV| VSX LX-60 | 42PD7200 | DMREX77 | DMP-BD35 | BK MONOLITH-df (LAB12) | MA BRONZE | M5DS | M3DSi |7.1 lounge
PC| E8500@4GHz | COOLERMASTER 1KW | 4GB XMS3 DDR3 | HD4870 1GB | P5K3 Delx | XONAR D2X | M-AUDIO BX5a Delx | LIAN LI V2100B |PC
02-02-2009, 7:10 PM
#15
Nuwidol, I've made these comments previously on here. Although I'm by no means an expert on room design or home entertainment, my own view on TV heights is a pretty strong one - yes the viewing height is better at eye level, but when planning a room layout there is so much more to consider than just the height of the TV.
Personally, I think it is very easy to make a room look poorly planned with a TV set at eye level. For my set up, although I wanted to make the TV look as well positioned as possible, I didn't want it to dominate the room - which probably explains why I've hidden all the AV gear and was part of the process when we planned the height. (of the lane also has a cupboard 'opportunity' similar to mine!')
With that in mind - it's important that ofthelane positions the TV as HE thinks looks best. Personally, I don't find looking up by 5 or 6 degrees across 10 feet at all uncomfortable and think far too much is made of the watching position in relation to eye level!
There, you've got my opinion whether you wanted it or not!
02-02-2009, 8:27 PM
#16
Thanks: Gave 163, Got 104
I think a lot of TV positioning depends on whether you sit in the lounge to watch TV, or watch TV occasionally whilst sitting in the lounge  . Which is why so many mention the eye level thing in these threads (being an AV forum n all!) Like everything it's just personal choice though.
Looks like you've made a good start with this one mate! Funny how fashion comes and goes, can't ever see these brick fireplaces coming back can you, but I guess they will...
Sam
PSN: LEUMAS_10
02-02-2009, 9:25 PM
#17
Cheers Leumas..Yeah fireplaces are a thing of the past now might need it when Im old though!! lol
03-02-2009, 11:06 AM
#18
Thanks: Gave 33, Got 26
Thanks for looking.
Front Speakers x 3
Rear Speaker
Looking good there mate.....
What do you think of those speakers? I was thinking of getting a pair for my rears in a 7.1 set-up. Seams mad to spend a fortune on speakers that will only be picking up ambient sounds. I always worry when things are too good to be true and these are falling into that category (very well priced though).
May be worth test fitting one into a wall to hear what they are like before you design your construction around them.
Would be interested in your opinions after?
Good luck with the project
My Floating Wall Project - Come and see
Panasonic TH-50PZ81B / Denon AVR-3802 / Denon DVD-2800 / PS3 60gb / Wii / Virgin V+ / Kef KHT1005 / Harmony 1000
05-02-2009, 7:42 PM
#19
How is this build getting on?
05-02-2009, 10:16 PM
#20
Thanks: Gave 20, Got 89
Yes , come on . Chop chop , how are those speakers (i'm thinking of something like that now )
06-02-2009, 10:44 AM
#21
Thanks: Gave 24, Got 43
Hi there,
I was thinking about changing my rear for some Monitor audio in walls. Are they easy to fit.
cheers
Graham
06-02-2009, 3:39 PM
#22
Originally Posted by gperkins1973
Hi there,
cheers
Graham
Hi Graham..yes i believe they are very easy to fit..I've been back on shift so the work has slowed down a bit but will be starting again tomoz and hopefully have the speakers in.
I'll keep you posted.
Ted
06-02-2009, 3:43 PM
#23
Just got the MDF up..cables getting sorted tomoz then hopefully all systems go...
Forgot to put a Picture of my rear speakers...see below..
Wire's will be hard to see once properly covered..hopefully..
06-02-2009, 3:48 PM
#24
Stage 3 MDF Up....Loads of the cables to sort out through a hole on the chimney breast..all of them are tagged with the respective places to go..
06-02-2009, 3:50 PM
#25
And a side view...
06-02-2009, 3:59 PM
#26
Some nice progress there. Looking forward to your review on those in walls............
My decision to purchase a pair depends on it
06-02-2009, 4:37 PM
#27
Ok m8 no probs..
07-02-2009, 10:40 AM
#28
Location: Perth, Western Australia (Originally Ireland)
Thanks: Gave 73, Got 68
Originally Posted by Repton
Great job so far!
Agree, and particlularly agree with the second statement!
08-02-2009, 10:02 PM
#29
Yes maybe so but as I first opened this thread I did say I was new to this forum and made a mistake by putting My Home Entertainment System Project on this topic..
Anyway just had my friend the Joiner Craig come round yesterday and he cracked on a bit more all main frame now complete main MDF up next, cables a bit more tidy now just a few to sort out.
08-02-2009, 10:03 PM
#30
