My Home Entertainment System Project
Old 10-02-2009, 8:05 PM   #31
thefathacker's Avatar
1,922, Level: 10
Points: 1,922, Level: 10 Points: 1,922, Level: 10 Points: 1,922, Level: 10
Thanks: Gave 16, Got 3
Re: My Home Entertainment System Project
Originally Posted by Repton View Post
Great job so far!
This is more suited in the DIY projects section of the forum though.
Which will answer something I've been wondering about. Can anyone move a thread or is that restricted to Mods?
Old 10-02-2009, 8:52 PM   #32
1,820, Level: 9
Points: 1,820, Level: 9 Points: 1,820, Level: 9 Points: 1,820, Level: 9
Thanks: Gave 3, Got 3
Bit more done today and some paint work..
Stage 5 three photos.
Old 11-02-2009, 2:01 PM   #33
Indecisive's Avatar
3,035, Level: 12
Points: 3,035, Level: 12 Points: 3,035, Level: 12 Points: 3,035, Level: 12
Thanks: Gave 33, Got 26
I can see where your going with this now, looking good.
How are the blue and white rope lights going to be operated (through lighting circuit or plug socket)?
Not tried those in wall speakers yet? Come on...........
Old 11-02-2009, 6:24 PM   #34
1,820, Level: 9
hi m8..plug socket through a dimmer..if you look to the left you can make out the three way dimmer thats taped up on the side wall..No still not got speakers set up but will be very very soon.. Thanks for comments m8..
Old 15-02-2009, 1:06 PM   #35
1,820, Level: 9
Rite so I came home from work last nite and Craig (the Joiner) had completed the front...I was amazed, it looked fantastic, should be painting it this week and the two end cupboards will be in next weekend and the front door and hopefully it all should be finished.
Now my friend thefathacker came round to help with all those wires and where they go, everything is all connected up now but I need to buy a decent sub, I’ll be looking for one soon, indecisive the front speaker's seem to be O.K for now but I can’t really tell till the subs connected up, my friend thefathacker thinks there not up to much but I’m not too sure yet, I'll let you know in the week.
Stage 6..
Old 15-02-2009, 1:18 PM   #36
5,973, Level: 18
Points: 5,973, Level: 18 Points: 5,973, Level: 18 Points: 5,973, Level: 18
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 178, Got 64
Looking good, can't wait to see it all finished.
Old 15-02-2009, 3:46 PM   #37
1,820, Level: 9
Thanks a lot..
Old 17-02-2009, 8:39 PM   #38
j0t4b3's Avatar
1,284, Level: 8
Points: 1,284, Level: 8 Points: 1,284, Level: 8 Points: 1,284, Level: 8
Thanks: Gave 4, Got 6
Ofthelane -
Great job!
I do have a question, though, that relates to the airflow behind the TV. how does air circulate behind your screen?
THey don't heat up much, but from the pictures I can't see where the hot air can go.
Thanks for sharing your pics!
Old 18-02-2009, 8:01 AM   #39
1,820, Level: 9
Originally Posted by j0t4b3 View Post
Ofthelane -
Great job!
Thanks j0t4b3....I am gambling with this one as with the amp to, although I've kept an eye on the heating up of the T.V and it seems ok at the mo..the amp is defo a problem but I can cut a hole through the top of the wood that go's into the chim breast, but then I have debris probs from the chimney...may-be some very fine mesh will stop any debris falling down..it's a problem I need to address asap..
Thanks for looking.
Old 18-02-2009, 3:24 PM   #40
j0t4b3's Avatar
1,284, Level: 8
You could cut some lateral holes high at the amps case, then add a CPU cooler or similar. That will pump out the heat.
you could easily add some plastic tubes to the sides of your built furniture... problem with the fan can be the noise... and how to power it up...
my 2 cents...
Old 18-02-2009, 3:53 PM   #41
1,185, Level: 7
Points: 1,185, Level: 7 Points: 1,185, Level: 7 Points: 1,185, Level: 7
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
Thanks: Gave 14, Got 9
Hi mate. just wanted to say I like what you're doing there.
One question: are you plastering on top of the mdf?
I'm about to start doing a similar thing in my dining room so very interested in how you get on with yours.
Very impressed with it so far.
Stuart.
Old 19-02-2009, 10:51 AM   #42
1,820, Level: 9
Stuart.
Hi Stuart...no not plastering..just painting a undercoat then rub the MDF down with very fine sandpaper then add a few more coats you get a very smooth finish when you rub it down..and it takes no time..little dusty..but worth it m8..
Old 27-02-2009, 2:53 PM   #43
1,820, Level: 9
Well I know it’s taking time but I’ve been really busy at work lately I was hoping to all done last weekend but due to work commitments I’ve had not much time to do things.
I’ve painted the front and hopefully the cupboards should be on tomoz.
I must say that the sound Quality is fantastic I bought a Sub-woofer from Richers sounds for £200.00 its perfect!! made by Cambridge Audio.
The remote is the best although pricey at £177.00 it is the dogs!! Easy to use and stops all the messing about..Top draw, it’s a Logitech harmony remote control..Really is fantastic.
Well hopefully the next set of photos after the ones below will be the last and my project, which I think has been a great success will be finished.
Thank you for looking.
Old 27-02-2009, 2:56 PM   #44
1,820, Level: 9
Old 27-02-2009, 2:57 PM   #45
1,820, Level: 9
Old 27-02-2009, 2:57 PM   #46
1,820, Level: 9
Old 27-02-2009, 2:58 PM   #47
1,820, Level: 9
Old 28-02-2009, 9:02 AM   #48
s_inman's Avatar
4,279, Level: 15
Points: 4,279, Level: 15 Points: 4,279, Level: 15 Points: 4,279, Level: 15
Activity: 32.1%
Activity: 32.1% Activity: 32.1% Activity: 32.1%
Thanks: Gave 67, Got 91
Cant see the pictures .
Old 28-02-2009, 3:38 PM   #49
2,865, Level: 12
Points: 2,865, Level: 12 Points: 2,865, Level: 12 Points: 2,865, Level: 12
All pics: photobucket: bandwidth exceeded
Old 28-02-2009, 8:45 PM   #50
Indecisive's Avatar
3,035, Level: 12
Shame I cant see your pics, I bet it's really looking nice though. So now you have the in walls set up along with a Sub to give them the depth, would you recommend them as part of a HC set-up? What is thefathacker's opinion of them now?
Old 02-03-2009, 2:01 PM   #51
1,820, Level: 9
Hi Indecisve...I will sort out the photos soon photobucket is a pain in the arse..
I would recommend the speakers but perhaps go for the 100w and not the 75w..but to be honest the sound out my system is fantasic well chuffed with it..
I'll sort out those photos later.
Old 02-03-2009, 3:55 PM   #52
2,055, Level: 10
Points: 2,055, Level: 10 Points: 2,055, Level: 10 Points: 2,055, Level: 10
How easy is it to remove the TV if needed?
Looks great btw!
Old 02-03-2009, 4:17 PM   #53
1,820, Level: 9
Looks great btw!
Very easy it's on a big bracket that swings out..
Thanks for the comments.
Old 02-03-2009, 4:22 PM   #54
1,820, Level: 9
Just done the light now...Still a bit of painting to do but nearly there...Well made up with it all looking and sounding really good..
Old 02-03-2009, 4:26 PM   #55
1,820, Level: 9
Old 02-03-2009, 9:37 PM   #56
7,730, Level: 20
Points: 7,730, Level: 20 Points: 7,730, Level: 20 Points: 7,730, Level: 20
Thanks: Gave 187, Got 130
Coming along well.
Old 07-03-2009, 7:20 AM   #57
Indecisive's Avatar
3,035, Level: 12
Thanks for the update on the Adastras. Was just about to order them the other day but then stumbled across a pair of Sonance Symphony S621t's on the bay that had been listed incorrectly. The hope that no one else would notice them paid off and I got myself a pair of £299 in walls for £56, so quid's in and a higher end sound to boot. Arrived next day in mint condition and they sound sublime
You install is looking very clean and I am sure you are loving every second of the entertainment it's rewarding you with for all the hard work that's been put into it.
Any chance of a few low light shots to show off the back lighting. Can't make out the blue behind the TV in the pics you have posted.
Old 07-03-2009, 11:11 AM   #58
1,820, Level: 9
Thats good m8 nice 1..great when ya bargins like that..
Will take some more photos..the blue lights not very bright may have to shop around for a better ones...Ikea do some good ones my friend thefathacker has them he likes his....
Old 07-03-2009, 11:21 AM   #59
Indecisive's Avatar
3,035, Level: 12
Thats a shame.....
I was going to go for something like these
4 x 9" HOME THEATRE CINEMA AMBIENT LED MOOD LIGHTING on eBay, also LED Lighting, Lights, Lighting, Home Garden (end time 13-Mar-09 10:19:11 GMT)
wouldn't be stuck with just Blue either. They look really bright in the pics and are remote controlled.
Old 07-03-2009, 5:03 PM   #60
1,820, Level: 9
Thats a shame.....
Excellent..I've just bought them thanks for the info..let ya know wat there like..Thanks again..
