Go Back   AVForums.com > Computers > Mac Hardware, OS and Software
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Bad SKY PQ with new Pana TX-32LXD80 - Help Needed pthomson Sky and Sky+ 25 12-05-2009 10:40 PM
my arcam system - not as good as it should be ? Tbone68 Arcam Owners' Forum 42 16-01-2009 10:37 AM
PSP flashed with 3.71 m33-2 what now ?? Rad PSP 8 15-01-2009 11:50 AM
Im gonna Breed my dog! SyStemDeMoN General Chat 49 15-01-2009 11:33 AM
Choosing the right company to upgrade my aerial ? crowds Freeview 8 14-01-2009 4:34 PM
Old 14-01-2009, 2:04 PM   #1 (permalink)
Thanks: Gave 28, Got 32
Help with my macbook air
HI guys, i have just bought a macbook air, and with i i also bought the micr dvi to dvi and micro dvi to vga. I would ike to hook the macbook up to my television, however the component cable on my tv is taken up by y ps3 and i use the av cable for my iphone to tv connection. I have scart plugs on my tv would that be the best way to connect the macbook up, and also would the scart connection transfer both video and sound. Any help much appreciated. Thanks guys.
xXxtommyboy21xX is offline   Reply With Quote
Old 14-01-2009, 2:17 PM   #2 (permalink)
Conspicuous Member
Thanks: Gave 141, Got 586
Re: Help with my macbook air
Apple Micro-DVI to Video Adapter - Apple Store (U.K.)
micro DVI to video will give you svideo output which should be supported on one of your SCARTs.
Then you need a 3.5mm to twin phono lead for the audio (couple of quid from maplins) and a SCART plug with svideo+twin RCA sockets on it (also a couple of quid from maplin)
Do you not have a HDMI socket or VGA or anything like that? Svideo will be ok for watching videos but not great for using it as a computer.
richard plumb is offline   Reply With Quote
Old 14-01-2009, 4:18 PM   #3 (permalink)
Thanks: Gave 20, Got 42
S-Video will give you a very bad picture, connect it via VGA or DVI if possible, if not i wouldnt bother.
Digitalize is offline   Reply With Quote
Old 14-01-2009, 5:42 PM   #4 (permalink)
i already have a micro dvi to dvi connector, so could i use a dvi to scart to connect the macbok to the tv, and also do you have any idea how the picture quality would be?
Old 14-01-2009, 5:45 PM   #5 (permalink)
or would it be possible to connect a the computer as followis:
micro dvi TO dvi
and then
dvi TO scart
WOuld that transfer both video and sound, and also what would the quality be like?
Old 14-01-2009, 5:58 PM   #6 (permalink)
istanbul05's Avatar
Thanks: Gave 55, Got 67
As Digitalize said earlier, scart wouldn't give a pretty picture and i wouldn't bother unless you really needed it. DVI doesn't carry sound so you would need to connect the sound up via the headphone port on the Macbook. Connect it via HDMI, VGA or DVI if possible.
istanbul05 is offline   Reply With Quote
Old 14-01-2009, 7:02 PM   #7 (permalink)
what about:
micro dvi to vga and then vga to scart, or would the picure still not be great?
Old 14-01-2009, 7:06 PM   #8 (permalink)
Conspicuous Member
the video adapter I linked to is the only way to hook up to SCART. all the others are HD sources and you'll need the matching connector.
DVI will need either DVI or HDMI (via a converter)
VGA will need a VGA input
What telly do you have? if it has component does that take HD? Wonder if there is a way to get HD over component if its compatible and you could use a switcher? - no HDMI or VGA inputs at all?
Old 14-01-2009, 8:28 PM   #9 (permalink)
hi there, i have a KLV-l23M1 tv
I am really confused at the moment on what to do, are you saying that it is not possible to use a vga to scart like this one:
Search Results: SCART 30/2
bearing in mind my air came with a micro dvi to vga connection.
Any help much appreciated, thanks.
Old 14-01-2009, 11:13 PM   #10 (permalink)
Conspicuous Member
no, that won't work. Its designed to work the other way around so you can plug SCART stuff (eg a sky box or freeview box) into a projector that'll take RGB but doesn't have a SCART socket.
reading the user manual for that TV, you only have component inputs that would accept a HD signal. I don't think you're going to have any luck getting the two working together.
You'd need a new monitor which has VGA or DVI built in (or HDMI but then you'd need a DVI-HDMI converter)
Old 15-01-2009, 6:32 PM   #11 (permalink)
thanks very much richard, one last question. do you think vga to component would work?
Old 15-01-2009, 8:00 PM   #12 (permalink)
Conspicuous Member
personally I doubt it. But try and read up more on that tv to see if anyone has tried it.
air, macbook
