Originally Posted by screemer
i have a growing number of music, films and pics on my iMac. i want an external HDD both to put them on and to back them up to. Am i best going for the time capsule with wireless access etc or just a firewire drive like a WD one? i want to be able to stili access the content on my Apple tv when i get it.
Is there a definitive answer about 'off-line' support for ATV?
For Screemer - The ATV is an extension of iTunes with the ability to store info locally to save running your Mac 24/7. If all your iTunes content is on an external HDD you can either sync iTunes and store upto the capacity of your ATV (40GB or 160GB) locally, or you can stream it from the external drive via iTunes. I don't think you can stream direct from the external drive to the ATV. (Does that make sense?)
As for other comment re. storage v. backup, if you put you entire iTunes library on an external drive and it fails you will lose it all. Personally I use a Wester Digital dual disk enclosure running as a 500GB mirror, so that's one box containing 2 x 500GB drives but my iMac only sees 1 x 500GB. When my iMac writes to the drive, the drive automatically puts the info onto both drives. This way if 1 drive fails the data is protected.
