Go Back   AVForums.com > Computers > Mac Hardware, OS and Software
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
HOW TO: connect XBOX to DVI monitor with sound! daljsd Xbox 360 5 02-02-2009 10:30 AM
Some help with playing TrueHD on the 'Yamaha Dspax761' please Dave_L AV Amplifiers and Receivers 13 05-01-2009 12:54 PM
Marwell Zoo -First Outing with My 70-200mm VR psenior1 Digital Photography General Chat 10 04-01-2009 5:39 PM
Advice needed on 32" lcd RichardUK39 Which LCD TV Should I Buy? 4 03-01-2009 7:37 PM
On line light don-tucker Virgin Media 3 03-01-2009 7:19 PM
Old 03-01-2009, 4:42 PM   #1 (permalink)
The Spaniard's Avatar
Thanks: Gave 28, Got 78
Problem with movie files on ipod - Help please
Hi All,
Trying to use mac the ripper and then handbrake to convert dvd's to play on my classic 30gb ipod but having no luck and am bamboozled
It doesn't matter what setting I use in handbrake to create the M4v file (ipod high or low res) I get the message that the file cannot play on ipod when trying to sync despite the file playing perfectly within itunes itself? Any ideas
If I convert files recorded from eyetv they play no problem at all?
Please help guys as I wanted to copy a few of my comedy dvd's for a forthcoming skiing holiday!
Regards Gary
The Spaniard
The Spaniard is offline   Reply With Quote
Old 03-01-2009, 5:33 PM   #2 (permalink)
Thanks: Gave 6, Got 5
Re: Problem with movie files on ipod - Help please
I found handbrake a doddle to use once I got the knack;
Insert DVD
Select it in handbrake
Then expand the presets on the right hand side (you may have to select show presets).
Select Ipod and set it off.
Jiff Lemon is offline   Reply With Quote
Old 03-01-2009, 5:54 PM   #3 (permalink)
sammy4499771's Avatar
Thanks: Gave 31, Got 91
Did you convert the eye tv recordings in handbrake? The only thing i could suggest is try to update the presets in handbrake.
250 gb Apple TV | Macbook Pro | iphone 3G
sammy4499771 is offline   Reply With Quote
Old 04-01-2009, 1:23 AM   #4 (permalink)
Jiff - don't you have to rip the dvd first using mac the ripper?
Sammy - eyetv does it all including the recording and the conversion - you don't have to use handbrake
Regards Gary
The Spaniard
Old 04-01-2009, 7:23 AM   #5 (permalink)
Thanks: Gave 0, Got 3
You can rip with Handbrake - but with version 0.93 you have to have the latest version of VLC installed in your root Apps directory. In the older versions of Handbrake it did the rip for you. Most people stick with MTR though ..
As was suggested earlier, make sure that you have updated the built-in presets, especially if you have upgraded to 0.93 recently - they all changed. Also, you say that it's a "Classic 30gb" iPod - do you mean the iPod 5G ? If so, you need the iPod 5G flag in Handbrake ticked. I encode all of my Handbrake stuff for my iPod 5G using the legacy, iPod setting and it works fine.
If you are still having problems, let us know exactly which program versions and iPod you have, and we'll see what we can do.
DillonTheCat is offline   Reply With Quote
files, ipod, movie, problem
