Go Back   AVForums.com > Computers > Mac Hardware, OS and Software
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
New Monitor for MacBook Aluminium and PS3 Indie1984 Computer Monitors 4 26-10-2008 12:19 AM
macbook and external monitor - tips? richard plumb Mac Hardware, OS and Software 12 22-06-2008 9:07 AM
LCD Monitor for Macbook - which one?? Unlight Mac Hardware, OS and Software 9 23-05-2008 8:14 PM
New Xbox 360, Macbook As A Monitor?? greavsy69 Xbox 360 2 26-11-2007 10:29 PM
Old 26-10-2008, 12:13 AM   #1 (permalink)
Thanks: Gave 9, Got 6
Hi all,
I have just started at Uni and was needing a Monitor to stop me slouching looking at my teeny 13.3" MacBook screen, I have the new MacBooks that were launched 2 weeks ago so I can support a resolution of 1920x1200. Now I would go for a Standard Apple 24" display but I also want to run my PS3 through the Monitor preferably through either HDMI or DVI. So if anyone has an Suggestions of a good 24" Monitor with a resolution of 1920x1200 and a half decent contrast Ratio I'll be happy to have a look :D
Chris
Indie1984 is offline   Reply With Quote
Old 26-10-2008, 1:26 AM   #2 (permalink)
Robfrancis's Avatar
Thanks: Gave 3, Got 37
Re: Monitor for MacBook Aluminium and PS3
If you have the funds to get an apple one then go with them. they make the cinema HD displays that are the best monitors i have ever seen (the most expensive too though @ £600 for the 23" ), although i can't comment on the brand new ones as i have never seen one.
Failing that get something like THIS 24"dell , Full HD with enough ports to have your ps3 and mac set up at the same time (DVI/HDMI/VGA) but you lose 120 vertical pixels as it s 16:9 not :10. That would be a budget 24" option that gets good write ups from reviewers and buyers alike.
or something like THIS BenQ 16:10 DVI/HDMI/VGA, 4000:1 contrast, 2ms response.
Really just depends on your budget/ what your going to be doing with it. just because your MB can support that res doesn't mean that you have to go all the way up to it but if you are going to have your ps3 on there as well it would be a bonus to have full HD
'Nice comeback, Does it come in witty ??'
Gaming: q6600@ 3.25ghz / 8800gt / 4gb TwinX
Dev: MacBook Pro / 15" Matte / 2.2ghz / 4gb
Robfrancis is offline   Reply With Quote
Indie1984 (26-10-2008)
Old 26-10-2008, 1:37 AM   #3 (permalink)
Many thanks for the reply,
The Dell Monitor looks very nice indeed and at the price I can't really complain either.
I have used the new LED 24" Display (I work in the Apple store in Leicester) and think it looks good, but I can't run anything through it like my PS3 which whilst at Uni is also my Digital TV tuner and PVR with the Sony PlayTV, Also for the £600 price tag I could pick up a much better Monitor in all honesty, Sure it won't look as slick as the apple one with intergrated iSight but I honestly don't need that.
Chris
Old 26-10-2008, 1:48 AM   #4 (permalink)
Robfrancis's Avatar
Np mate. Hope it helped you along a bit good luck !!
I have been having a few problems with apple at the moment over a couple of things an need a bit of advice from someone who works there but isn't on the clock. Would it be ok if i PM'd you with a couple of questions tommorrow. Nothing dodgy its just that i have been having a few issues with my MBP and when i went to get them seen to i basically got shunned off and laughed at. i want to know where i should go next. Its ok if you don't want too just let me know !
Old 26-10-2008, 8:48 AM   #5 (permalink)
Conspicuous Member
Thanks: Gave 141, Got 586
I bought a samsung T220HD which is a 22" widescreen monitor (1680x1050), with DVI, VGA and HDMI inputs, along with component, so you can connect your computer and games consoles (I connected a sky+ box). Plus it has a freeview tuner built in, and speakers.
perfect for my needs, which was a TV for the spare room, that could double up as a monitor for my macbook
they also do a 26", 1920x1200 version, but that was too big for my room.
richard plumb is offline   Reply With Quote
Old 26-10-2008, 9:31 AM   #6 (permalink)
ash
ash's Avatar
Thanks: Gave 630, Got 420
I'm tempted by the Dell as well to go along with the Alu MacBook...
Batman Begins at IMAX!
ash is offline   Reply With Quote
Old 26-10-2008, 9:59 AM   #7 (permalink)
Thanks: Gave 108, Got 1,462
Bare in mind that any display used with a PS3 will have to be HDCP compatible. I would imagine that most if not all of them are these days but I suspect that there still may be some especially budget ones that aren't.
60GB PS3, Wii, Xbox 360 Elite, DSi, PSP Go, Toshiba EP-30 HD-DVD, MacBook Air, 16GB iPhone 3G, Canon EOS 450D
My opinions are my own and do not represent the AV Forums
Moogle is offline   Reply With Quote
Old 26-10-2008, 11:27 AM   #8 (permalink)
Thanks for the info Moogle, I've just checked and the Dell is HDCP Compatible :D
I think I'll be ordering it some time next week.
Old 26-10-2008, 11:46 AM   #9 (permalink)
LFC_SL's Avatar
Thanks: Gave 971, Got 1,856
When buying a monitor, it is important to consider the panel type
I had a budget and bought a Samsung 215TW. Discontinued model then when buying and now, but very much in my mind it was not using a cheaper TN panel
The DVI input is also HDCP compatible so it has resale value
Opinions expressed here are my own and do not represent those of the AV Forums or its associated websites
Selling my Aluminium Macbook | Trading Rules - Read for Your Protection | DVDs
LFC_SL is offline   Reply With Quote
Old 26-10-2008, 12:12 PM   #10 (permalink)
ash
ash's Avatar
Remember to go through Quidco for the Dell monitor
aluminium, macbook, monitor, ps3
