04-01-2008, 12:35 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 80, Got 95 | why do my applications keep quitting?
as most of you know I took delivery of my new macbook yesterday and loving it.
the only thing is in the last 24 hours of use it has quit several applications and asked me to relaunch them. this is especially annoying when on the internet as when it relaunches it takes me back to my home page.
what could be the cause of this...I've got safari/mail/itunes open. Everything keeps running fine apart from this. Is this a new problem for 10.5 as it never happened on my old macs
__________________ Macbook aluminium 2.4 Ghz|Logitech MX Revolution Mouse|Graham Slee Solo Headphone Amp + PSU1 Upgrade|Fubar II DAC|Sennheiser HD650 Headphones|Kimber 1011 Interconnect|iPhone 3g|ipod nano|Canon 400D |
04-01-2008, 12:44 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 19, Got 96 | Re: why do my applications keep quitting?
I think mate it is a Leopard quirk, as i have noticed it a fair bit since upgrading. Hopefully they will iron it out soon.
04-01-2008, 1:00 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 80, Got 95 | Re: why do my applications keep quitting?
Thanks again nick for your reply  I'm glad its leopard and not my mac  I suppose being on 10.5.1 there'll be a few updates to be applied over the next few months!
04-01-2008, 1:30 PM
#4 (permalink)
| | Senior Member
Thanks: Gave 42, Got 242 | Re: why do my applications keep quitting?
You'll have read here that safari seems to fall over at the puff of a breeze at the moment - especially with this website - possibly flash-related ...
Glad you are enjoying your new mac though ...
Jon
__________________ my toys ... Arcam FMJ AV8, P7, DV27A | B&W 805s & HTM2 | Anthony Gallo Micros & sub | Sanyo Z4 | Samsung LE37R8 | SkyHD | Toshiba HD-E1 | Sony BDP-S550 | xBox360 Elite | Wii | AppleTV | Harmony One | iMac 3Ghz, MacBook Air 1.86Ghz (ssd) & MacMini 2.16Ghz | Nikon D300 & 17-55mm f2.8 | 32Gb 3Gs iPhone |
04-01-2008, 2:15 PM
#5 (permalink)
| | Veteran Member
Thanks: Gave 32, Got 657 | Re: why do my applications keep quitting? Quote:
Originally Posted by Nick pavey I think mate it is a Leopard quirk, as i have noticed it a fair bit since upgrading. Hopefully they will iron it out soon. | Its happening to me since the upgrade to 10.4.11, mostly with Mail but others also.
04-01-2008, 6:01 PM
#6 (permalink)
| | Member
Thanks: Gave 93, Got 92 | Re: why do my applications keep quitting? Quote:
Originally Posted by Arcam_boy this is especially annoying when on the internet as when it relaunches it takes me back to my home page. | Not a fix, but you can choose to Reopen All Windows From Last Session from the History menu in Safari. Seems as if Apple were pre-empting Safari crashes!
05-01-2008, 9:32 AM
#7 (permalink)
| | Member
Thanks: Gave 3, Got 15 | Re: why do my applications keep quitting?
I've noticed huge problems when doing an upgrade from Tiger to Leopard on my 3 Macs. Instability, things not working right etc.
Doing a clean install of Leopard has completely done the opposite. This thing is fast, stable and just works (well the functionality I use does anyway).
Seem the upgrade process isn't a good as Apple claim it to be and suffers from the same problems that a Windows upgrade does.
If you can, backup your local disk to an external using SuperDuper or equivient, clean reinstall Leopard on it and see how that works for you. If it still crashes then I'd start to suspect hardware.
05-01-2008, 11:06 AM
#8 (permalink)
| | Senior Member
I've a brand new shipped-with-Leopard MacBook and an upgraded-to-Leopard PowerMac and they both have a flaky safari - seems the shipping version of 3.0 isn't as stable as the beta ...
For those with an intel-mac then Camino comes highly recommended as an alternative browser and BonEcho does specific PowerPC builds of Firefox for older macs ...
Jon
05-01-2008, 11:15 AM
#9 (permalink)
| | Veteran Member
The beta was really flaky for me so I waited on the release.
However Safari hasn't quit once on my (10.5) MacBook or (10.4) iMac. Now Mail and other apps are falling over, Mail esp. others less frequently. Just goes to show how unique each of our installations is.
FWIW I would recommend Firefox all the way on either platform, those add-ins and java/flash controls are invaluable.
05-01-2008, 11:21 AM
#10 (permalink)
| | Member
Thanks: Gave 50, Got 70 | Re: why do my applications keep quitting?
Skype always seems to crash on me - either half way through a video call or when the call has ended and hung up
Not useful
Shaz
__________________ TV KDL32V2000, DVD Toshiba HD-E1, AMP PIONEER VSX 2016, SPEAKERS MS Avant Premiere 6.1, REMOTE Harmony 885, SKY SKY HD, CONSOLE PS2, PSP, Wii, PS3 MP3 PLAYER Archos Gmini 202s, Ipod 80gig Wii code 1150 6698 3568 5621 (PM if you add me), PS3 ID fizl
05-01-2008, 11:42 AM
#11 (permalink)
| | Veteran Member
Off topic, but as Skype has been mentioned (and it never crashes on me - latest build) does anyone know how to place contact pics in the Skype cards?
05-01-2008, 12:11 PM
#12 (permalink)
| | Member
That's really bizarre that you guys have all these problems. I work with 100s of Mac and everything just works. No crashing, no hanging and no kernal panics.
I wonder if the image of Leopard that Apple puts on all new machines has a problem?
05-01-2008, 12:17 PM
#13 (permalink)
| | Member
Don't know - but it is only skype and safari that quit for me.
I did a repair permissions this morning that found loads of problems with flash permissions, so fingers crossed that will fix the safari problem.
Looking at skype, apparently it is greedy and doesn't like sharing - so if you have ichat running at the same time it gets upset at the thought of sharing the isight cam, so have been trying only running one or the other app (tbh am preferring ichat at the moment)
shaz
