Go Back   AVForums.com > Computers > Mac Hardware, OS and Software
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
road tax disc question Proto Omega General Chat 5 13-07-2009 12:58 PM
Crossfire question - no performance gain in crysis warhead Sunshinewelly Graphics Cards, TV Tuners and Webcams 13 07-07-2009 10:50 AM
HDMI to DVI cable question Y.M.S HDMI Cables and Switches 13 06-07-2009 3:44 PM
A question about X-fi and SPDIF simeonipicker Home Cinema PCs 0 04-07-2009 8:10 PM
Network Question Jakks Xbox 360 Hardware 2 04-07-2009 7:52 PM
Old 04-07-2009, 10:24 PM   #1 (permalink)
Thanks: Gave 1, Got 2
iPhoto Question
I have imported all my photos using iPhoto 09. Question is where are the photos exactly on my harddrive as I can not find them anywhere and I want to ensure they are in folders etc..
NeilW555 is offline   Reply With Quote
Old 04-07-2009, 10:46 PM   #2 (permalink)
cracker's Avatar
Thanks: Gave 19, Got 227
Re: iPhoto Question
in your home folder in the Pictures folder there is a file called "iPhoto Library". This is the package containing all your iPhoto data
If you right-click on this file and choose "show package contents" you can drill down to the directory where the photo files themselves are located. From memory i think they are in folders called "originals" and "modified" or something like that
PS3 60GB 250GB
iMac 24" 3.06GHz/4GB/1TB/512MB, MacBook Pro 15" Unibody 2.4GHz/4GB/250GB/256MB, AirPort Extreme, iPhone, iPod Touch 2G
cracker is offline   Reply With Quote
Old 04-07-2009, 10:59 PM   #3 (permalink)
Re: iPhoto Question
Can I reorganise them in originals because they are not how i want them.
I tried moving one of them but now it can not be viewed in iphoto
Old 04-07-2009, 11:24 PM   #4 (permalink)
Thanks: Gave 32, Got 657
Re: iPhoto Question
Don't mess with the iPhoto Library it is designed to be accessed only via iPhoto and trying to manipulate image files directly can compromise the entire library.
As to organisation you can do two things - either reorganise the way they are displayed in iPhoto and let the app take care of the folder structure or put the photos into the order you want outside of iPhoto and then tell iPhoto to reference the files but not consolidate them to a single library.
Are you familiar with Smart Folders? That's a useful way of organising stuff within the app.
Tenex is offline   Reply With Quote
iphoto, question
