Go Back   AVForums.com > Computers > Mac Hardware, OS and Software
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Thinking of buying a MacBook Pro adonaldson1986 Mac Hardware, OS and Software 58 11-07-2009 5:27 PM
Panoview DS-9106PM.GB Projection Screen Optavo Projector Screens 6 09-07-2009 2:12 PM
CRT and LCD screen Advice needed leeboy2k3 CRT Projectors 18 07-07-2009 2:01 PM
Old 03-07-2009, 10:26 PM   #1 (permalink)
Thanks: Gave 21, Got 41
Dust Behind MacBook Pro Screen
Ok so after the Superdrive of my MBP was fixed I was very happy! Then the day before yesterday I noticed three specs on the screen (at least I thought). Water, iKlear etc later I now know that the dirt is behind the screen. They do not look like dead pixels - I have done some of the online checks and I can't feel them outside the screen so whatever they are they are definitely behind the screen. I have gone through the usual can I live with it/can I not live with it (there is always the risk if Apple agree to replace the screen that I get a worse one) questions. I have a few questions - hope you can help:
Has anyone had this issue?
If so what did you do and what was the outcome?
I have done some searching online and if it is dust then Apple seem to repair with few questions asked but I just wanted to check for any local (ie UK) experiences (most of the online hits are from the US).
asimm is offline   Reply With Quote
Old 03-07-2009, 10:36 PM   #2 (permalink)
Thanks: Gave 143, Got 81
Re: Dust Behind MacBook Pro Screen
Give your local Apple store a call and see what they say, just don't give your name or any other details
fat jez is offline   Reply With Quote
Old 03-07-2009, 10:41 PM   #3 (permalink)
Cheers - tried to do this today with Regent Street and Bluewater (gave up on each call after waiting for 10 minutes). I was going to ask them if a screen repair was needed how big a job this was and how long it might take.
During my online searches there have been a few reports of Apple replacing the whole machine - not sure why, maybe the screen/lid replacement is costly.
Will try again tomorrow and was also going to try AppleCare.
Old 03-07-2009, 10:47 PM   #4 (permalink)
Thanks: Gave 32, Got 657
I think I'd get it changed, if its simply cleaning they should be able to turn it around quickly. If its not then a replacement Mac will be even quicker.
Tenex is offline   Reply With Quote
Old 04-07-2009, 6:47 AM   #5 (permalink)
Thanks - I have just realised I have wasted a bit of time doing some online dead pixel checks as you should not be able to see dead pixels when the machine is off? I think it's definitely dirt and I will get to an Apple shop when I can. There will then be the usual problem of getting there/getting back/how long they will take etc.
Superdrive now this - I am a real fan of my MBP but these faults are denting my confidence in it.
Old 06-07-2009, 8:20 PM   #6 (permalink)
In my usual try anything before taking it to an Apple shop (because they are not easy to get to and I worry how long they will keep the machine for) I phoned AppleCare who told me that:
If it is dust then they should be able to just clean it.
The job is not a big one and should only take a day.
I was a bit surprised by this, I thought that the screens were glued so I don't know how they can do this. I am also a bit worried that when they do it they might put in more dust than they take out - can't believe that they do this in a dust free environment. Anyway will pop into a store soon and see what happens.
Old 06-07-2009, 8:44 PM   #7 (permalink)
Thanks: Gave 9, Got 126
They can blow air through the screen to clean it. I had two replacement screens on my 2008 mabook pro before they just replaced it with a 2009 model. £369 for the replacement screens, than god it was still under warranty.
Pioneer Kuro LX5090, Xbox 360 x2, Harmon Kardon AVR255, Sky HD, AppleTV (hacked) x2, WDTV Live, Kef Q9 Centre, Kef Q3 Fronts, Kef Q1 Surrounds, SVS PB10-ISD Sub x2, Apple Macbook Pro 15", 2 x Lacie Network Space 1Tb, 4 x Lacie 1Tb
Sy1441 is offline   Reply With Quote
Old 06-07-2009, 8:51 PM   #8 (permalink)
OK thanks, had not heard of that one. Hopefully that won't be too big or long a job - not the 7-10 days they use as their standard quote!
Old 06-07-2009, 8:58 PM   #9 (permalink)
Thanks: Gave 100, Got 80
I recently had my screen replaced for this exact reason. First an apple service center wouldn't replace it as they said it was in tolerance Then i moved to Germany, took it to a mac store and hey presto (well a month later...) O had a new screen.
muzzi is offline   Reply With Quote
Old 06-07-2009, 9:48 PM   #10 (permalink)
Thanks - I don't expect that problem (but could be wrong) I asked AppleCare if there was a policy for dust like there was with dead/stuck pixels and they said no - any dust/hair etc was unacceptable and would be fixed. Was it a quick fix (for a new screen) or did you have to leave it with them for a week or so?
Old 08-07-2009, 10:27 PM   #11 (permalink)
Thanks: Gave 5, Got 1
Have you had this fixed yet?
I have a late '08 Unibody MacBook Pro and just today have noticed a small patch of dust. I always worry with Apple whether they will just turn me down, so was wondering about calling the tech support.
How small is your dust patch? I managed to get some pics, although they are pretty bad it is clear something is not right and I believe it to be the same as yours.
http://img6.imageshack.us/img6/2112/zi60197.jpg
http://img190.imageshack.us/img190/2120/zi60198.jpg
http://img229.imageshack.us/img229/9281/zi60199.jpg
(The dust is the bright circle, this is with the screen turned off and under a blue light)
http://img191.imageshack.us/img191/9937/zi60200.jpg
I hope you get yours sorted soon!
delude is offline   Reply With Quote
asimm (09-07-2009)
Old 09-07-2009, 8:15 AM   #12 (permalink)
delude - thanks for taking the time to take and post the pictures. If I can work out how to do it I will do the same. Yes your problem (especially the first picture) looks similar.
No - not fixed yet the problem I have is finding a time when I can reasonably get to an Apple Store twice (hand in and pick up) and can reasonably do without the MBP (never). I have a chance to go to Regent Street tomorrow but they don't have any appointments until Saturday (and now checking today no appointments at all). So this will take some time but I will post when I do go and let you know what happens.
Are you going to see if yours can be repaired as well?
Old 09-07-2009, 9:25 AM   #13 (permalink)
It's something that I would definitely like to get fixed, as I am one to always make sure my tech is protected, but after driving all the way to Brent Cross before only be told (with an iPod Touch problem) that the 'genius' couldn't see anything I think it would be easier to try and arrange something over the phone. That being said, am I right in saying that you only have 90 days phone support unless you have already bought Applecare?
Thanks for keeping me up to date, it will be much appreciated and if I can get to talk to somebody I will do the same.
Old 09-07-2009, 9:30 AM   #14 (permalink)
The 90 days relates to any support issue - but if your Mac is within its first year warranty then the phone contact is available to deal with repairs ie. you don't have to go to a store yourself.
delude (09-07-2009)
Old 09-07-2009, 9:41 AM   #15 (permalink)
Thanks - never really looked in to it before.
Just found this thread on MR - Should I take in my MB for dust behind the glass? UPDATE: Apple Replaced It! - Mac Forums
Someone had the same issue with the same model (yours is Allu right asimm?) and had it replaced.
Roughly how big is your 'dark spot' asimm?
dust, macbook, pro, screen
