Anyone else missing content?
Old 27-02-2009, 11:27 PM   #1
6,038, Level: 18
Points: 6,038, Level: 18 Points: 6,038, Level: 18 Points: 6,038, Level: 18
Thanks: Gave 201, Got 192
Just tried to change my sackboys appearance and there's some dlc items it won't let me select. Like the remote control and Chinese new year stuff for example.
Checked the store as well and there's stuff missing.
Anyone know what's going on or is it something to do with me upgrading my HDD?
Old 28-02-2009, 12:58 PM   #2
11,559, Level: 25
Points: 11,559, Level: 25 Points: 11,559, Level: 25 Points: 11,559, Level: 25
Thanks: Gave 386, Got 435
Re: Anyone else missing content?
You might need to re-download the new content to your new HDD if you didn't to a restore from a backup
Old 28-02-2009, 5:21 PM   #3
6,038, Level: 18
I did do a restore. I downloaded them again anyway so I'll try it again tonight.
Like I said there also appears to be content missing from the store. The Chinese stuff and the Valentine's level kit appear to be missing. I guess they were probably only up for a certain time with them being seasonal or something like that.
Old 02-03-2009, 4:10 PM   #4
11,500, Level: 25
Points: 11,500, Level: 25 Points: 11,500, Level: 25 Points: 11,500, Level: 25
Activity: 29.7%
Activity: 29.7% Activity: 29.7% Activity: 29.7%
Thanks: Gave 181, Got 338
If you've downloaded something previously then you can download them again. From the "downloads" menu in the PSN store you can see what you've installed in the past and ask for anything again. I had to do this when I decided to rebuild my LBP DLC file - eg. the spaceman isn't available on the store any more but still obtainable if you got it during launch week.
EDIT: umm, sorry, I think that's basically what you'd said in your post, duh! I think they definitely add and remove content over time so it's a good idea to regularly check the PSN store for updates.
