N00b question help please
Old 23-02-2009, 1:12 AM   #1
BIGPHIL69's Avatar
1,952, Level: 10
Points: 1,952, Level: 10 Points: 1,952, Level: 10 Points: 1,952, Level: 10
Thanks: Gave 52, Got 52
hi i have been loving going through this games community and hearting all my favourite levels
but when i check i can only see the first 8 levels i hearted
is there anyway to see all of them or is 8 the max?
Old 23-02-2009, 1:48 AM   #2
Thanks: Gave 24, Got 16
Re: N00b question help please
On the left hand planet go into 'My levels' on the first page it will show your levels (if you have published any), on the second page onwards it will show you your hearted levels, then after those it will show you your hearted authors. Press L1 and R1 to scroll through the pages.
Old 23-02-2009, 8:36 AM   #3
BIGPHIL69's Avatar
1,952, Level: 10
i konw this but it only shows me 8 levels i was wondering if 8 was the maximum amount
Old 23-02-2009, 10:55 AM   #4
spudtator's Avatar
2,411, Level: 11
Points: 2,411, Level: 11 Points: 2,411, Level: 11 Points: 2,411, Level: 11
Thanks: Gave 303, Got 224
Should show more than that mate. I've got 20+ hearted and they're all showing.
Old 23-02-2009, 1:00 PM   #5
BIGPHIL69's Avatar
1,952, Level: 10
okay cheers mate, may have been a network issue or something, i will try later
