Originally Posted by screemer Just got this yesterday for chrimbo. Amazing game. I have been playing some user created levels, which i personally think are great and i have collected a load of stickers etc. What do i do with those objects then? Is that stuff for using in my pod or when i create levels? Also, how do people create there own objects to give away?? Cheers |
The stuff you collect in the story levels, are sometimes for use in later (or earlier levels), to make something happen, like open a barrier. You can also use stickers to decorate your pod, other sackboys
. Some of the prize bubbles you collect will be new clothes for your sackboy, or as you said objects/decorations for use when creating your own levels.
As for stuff you collect in user created levels, these are pretty much the same I think... in that you are able to use them in your own creations.
As for creating objects to give away, I'm not totally sure, as I haven't done it, but if you follow the create tutorials it should show you how to make your own objects/robots etc which you can save into your poppit. I'm pretty sure you can then give these creations away as prizes on your own levels. So in theory you might see something you made in other peoples levels.
