Hi there
Anybody have a LG Arena and had any luck getting it to connect with a TomTom?
Specifically I have the TomTom 930, and I can get it to connect and make phone calls, but nothing on the Text messaging side works.
It is meant to be able to read aloud new texts and you can even send them from the TomTom but this bit is greyed out when connected to my phone. TomTom don't specifically support the Arena but this "doesn't mean it won't work" apparently. Just wondering if anyone else has had any luck?
Also, I am trying to connect to the Internet to get 'TomTom Services' and this is a complete pain in the ar!e. It asks for Access points and login details which I have got from my phone / T-Mobile and the rest from the TomTom support site, but it just won't connect. T-Mobile tell me I need to speak to LG for support?!?!
Anyone with any experience on either of these issues - or even Bluetoothing the Internet connection to a PDA or similar as this is probably the same - let me know your thoughts!
I loved the LG Arena when I first got it but now I keep finding problems with it and it's doing my head in. I am having to send it back to LG soon as it keeps turning off and on when I get incoming calls - really helpful. Wish I'd have stuck with Nokia!
Judi-mae
