i just got this set and its great! the only minor issue ist he reflection, otherwise its amazing
just got a few questions,
1) i saw there was an update , but when i search for it through the tv , it doesnt find it , any reason for that?
2) what does the new update actally do , i have .16 atm
3) what does the real cinema setting do ?
4) does it change to 24p when a 24p source is found, or do i have to do something?
thanks
Maybe your set is already updated? this would explain why the software isn't finding the update as it will be checking the version number and ignoring the file completely.
The update fixed the problem with not being able to adjust the True Motion settings which left the TV (according to Richer Sounds and a few others) as a judder fest. If you're not experiencing a problem then don't worry about it.
