Go Back   AVForums.com > Video Electronics > LCD Televisions > Which LCD TV Should I Buy?
Today's price checkPowered by
Samsung LE-32B450C4
Panasonic Viera TX-L37G10E
Toshiba Regza 32AV615DB
Sony Bravia KDL-40W5500
Samsung LE-32B450C4
Panasonic Viera TX-L32X10
LG 22LH2000
Samsung LE-40B530P7
LG 37LH3000
Panasonic TXL19X10
Samsung LE-37B550
 More...Prices updated November 25th at 8:30am and include delivery.
New Doctor Who to be announced! Who? mjb-av On Television 199 12-06-2009 4:35 PM
PS3 and Sky HD to connect to new TV - Advice needed benno321 AV Amplifiers and Receivers 11 06-01-2009 2:08 PM
Which of these brackets is best? sparklesmcgraw Flat Screen TV Brackets and Mounts 5 04-01-2009 1:50 PM
Sony s350 Picture Quality wezza13 Blu-ray Players 7 03-01-2009 9:37 AM
Sony BDP-S550 blu-ray player zoom facility bob 59 Blu-ray Players 14 02-01-2009 6:39 AM
Old 02-01-2009, 11:45 PM   #1 (permalink)
Thanks: Gave 2, Got 0
which to buy sony 40v4000 or samsung 40a656
I'm going to buy either the sony 40v4000 or samsung 40a656
I would like the sony 40w4500 but its a lot more money.
Which one shall I buy. My girlfriend thinks the samsung and i think the sony.
I know the sony has a 8bit panel and only 50hrz and
the samsung has 100hrz not sure on the panel bit
will i benefit from 100hrz
thanks for any help
peshi is offline   Reply With Quote
Old 02-01-2009, 11:55 PM   #2 (permalink)
Thanks: Gave 44, Got 27
Re: which to buy sony 40v4000 or samsung 40a656
thanks for any help
I had the same situation then got the 40W4000 and haven't looked back.
I perviously had a Samsung (LE37R88BDX) and the Sony beats it hands down in every department, colours are amazing.
Not sure if the new Samsungs are good or not though, judging by the reviews of the 656 I would say they have gotten better.
My Samsung was bought in 2006 so can't judge by todays standards.
Definitely happy with my purchase though.
As far as I know, Samsungs 100hz is poor and gives weird shapes around peoples heads etc. The 100hz feature varies in terms of performance etc by the people who make it.
Take a look at the following thread for example:
PROBLEM HELP: Samsung 40A756 - 100Hz Problem Blurring, Ghosting (I GOT Some PHOTOS)
That Samsung is a newer model than the one you are thinking of too.
Sony 40W4000 - PS3 Slim 120GB - Toshiba HD-EP30 - Sky+ HD (Samsung)
ll Deano ll is offline   Reply With Quote
Old 03-01-2009, 12:11 AM   #3 (permalink)
Thanks for your comments and thread deano.
Does any one know if the sony 40v4000 has the ps3 stile menu like the w series?
Thnkas
Old 03-01-2009, 12:15 AM   #4 (permalink)
Thnkas
Yep, sure does.
The only difference between the 40V4000 and the 40W4000 is that the 40W4000 has a 10-bit panel where as the V has 8-bit panel.
Can show better colours on the W because of it apparently, whether that is noticeable side-by-side is a different matter.
Pretty sure that is the only main difference.
Old 03-01-2009, 12:34 AM   #5 (permalink)
Thanks: Gave 2, Got 389
Not sure the V4000 has the PS3 style menus actually, not the ones I've seen anyway.
alsina is offline   Reply With Quote
Old 03-01-2009, 12:39 AM   #6 (permalink)
Shows the Menus on the 40V4000 on the following site:
Sony KDL40V4000 / KDL-40V4000 Review
Doesn't look the same as mine so would say they aren't like the PS3 and I stand corrected
Says they're a 'slightly cut-down version'
Old 03-01-2009, 4:28 PM   #7 (permalink)
thanks for that review link.
still cant decide weather to spend £3 - 400 more for the 40w4500
whats the best price anyone has found on the 40w4500?
Old 03-01-2009, 4:45 PM   #8 (permalink)
Thanks: Gave 3, Got 22
The Samsung has very good reviews as does the Sony but this years Sony stuff just looks like it's a couple of years old - what's with the really deep casing etc. My main tv is a Pioneer plasma and three years on it still looks cool although my Samsung has better blacks. (Freeview compares well on both - plasma and lcd btw)
I've looked at both makes for a long time and the extra 'bits' on the Sony seem to spoil the overall look of the set as a piece of furniture. I chose the LE40A686 because of the minimal 'picture frame' effect, solid reviews and because it's pretty good value for money at the moment.
Maybe Sony has better colours but as the Samsung is good enough, I figured the 100hz was a better bet for a smoother picture.
Can't fault it at present (Got it from Crampton & Moore for £655 inc 3 year warranty)
johnny-17 is offline   Reply With Quote
Old 03-01-2009, 5:04 PM   #9 (permalink)
Thanks: Gave 12, Got 2
I am in the same boat - nearly bought the 40w4000, but can not afford it.
Now back to the 40V or the sammy 40a656
Input - erm std tv (until I get a freesat box) and lots of Wii and Xbox.
Reviews are showing Sony to be the better - but I am not keen on the TV menu on the V4000 version - sammy looks a lot better.
batman1056 is offline   Reply With Quote
Old 03-01-2009, 5:08 PM   #10 (permalink)
Thanks: Gave 35, Got 107
I have the V4000 and my mate has the W4000 and I can't see any difference in quality. His has the PS3 style menues and a USB slot.
I'm very happy with my V4000 and couldn't justify the extra few hundred quid for a W
400GB PS3 | Sony 40V4000 TV
PSN: BlackRattie
bubs999 is offline   Reply With Quote
Old 03-01-2009, 6:12 PM   #11 (permalink)
can get the W for 669 - or the Sammy A686 for 686, or the 40v for around 550.
really tough decision¬!
Old 03-01-2009, 6:18 PM   #12 (permalink)
Thanks: Gave 9, Got 23
Got my 40V4000 yesterday. Just one question, you know the digital epg that sits on the top when you switch channel? Should that be black and white?
Gumpy Joe is offline   Reply With Quote
Old 03-01-2009, 7:26 PM   #13 (permalink)
batman where did you see the 40w4000 for that price?
thanks
Old 03-01-2009, 7:49 PM   #14 (permalink)
Sony KDL40W4000
£669 - think its a great price - 12 month warrenty free delivery (upto 20days!)
u fancy one?
I have decided to go with the 40V - looked at them both today - not much in it - and I'll save £200 - that will pay for my PS3
Old 03-01-2009, 7:51 PM   #15 (permalink)
Thanks: Gave 5, Got 2
Finally ordered my 40a686 there today after also considering the 40v4000 and the 40w4000.
I think the 40a686 was the right choice for me in the end. I think i shy'ed away from the sony's in the end because i had heard a lot of stories about motion blur and ghosting. The samsungs 100hz should prevent the motion blur anyway. And another thing, the 40a686 will be goin in a fairly dark room so its ultra clear panel should ensure that i'll get better blacks than the other two.
I'll be doin a good bit of gaming on them so input lag was a concern after reading hdtvtests review of the 656. However, some posters here claim that firmware updates have cut down the input lag a good bit, and that now, in PC mode over hdmi, theres the same amount of lag as the 40w4000. Its coming on wednesday and i cant wait
COR72Z is offline   Reply With Quote
buy, samsung, sony
