3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > LCD Televisions > Which LCD TV Should I Buy?
Today's price checkPowered by
Samsung LE-32B450C4
Sony Bravia KDL-40W5500
Panasonic Viera TX-L32X10
Panasonic Viera TX-L37G10E
Samsung LE-32B450C4
Toshiba Regza 32AV615DB
Samsung UE-40B7020
Samsung LE-40B530P7
Samsung LE-37B550
Samsung LE-22B450
Sony Bravia KDL-32W5500E
 More...Prices updated November 6th at 11:30am and include delivery.
Panasonic TX-32LXD80 TV - Up-Scaling Advice Needed jjsteph1969 LCD Televisions 3 03-01-2009 3:07 PM
Panasonic TX-32LXD8 same TX-32LXD80 ricjd Which LCD TV Should I Buy? 3 29-11-2008 11:39 AM
Sony KDL-32V400 motion blur leenzo LCD Televisions 30 26-11-2008 3:43 PM
Panasonic TX-32LXD80 Upscaling Advice Needed jjsteph1969 Which LCD TV Should I Buy? 0 24-11-2008 4:09 PM
Sony 32V400 and 100Hz smo59 Which LCD TV Should I Buy? 2 06-09-2008 5:45 PM
Old 02-12-2008, 10:40 PM   #1 (permalink)
Thanks: Gave 1, Got 0
32" LCD - Panasonic TX-32LXD80 or Sony KDL-32V400 or ...?
I’m looking to buy a LCD TV and have £450 tops to spend. It will be our main TV and viewed from a max distance of about 9 ft. I was thinking of getting a 32” screen – does this sound right? At the moment we have Tiscali TV but in the future we might go Sky. We tend to use video and DVD but are not gamers. What LCD would you recommend? I have been looking at the Panasonic TX-32LXD80; which I can get for £380 (Richter Sounds) or the Sony KDL-32V400 at £365 (Multizone).
What do you reckon folks?
MadDog169 is offline   Reply With Quote
Old 02-12-2008, 11:08 PM   #2 (permalink)
Thanks: Gave 55, Got 131
Re: 32" LCD - Panasonic TX-32LXD80 or Sony KDL-32V400 or ...?
I think you should go a bit larger at a 9ft viewing distance. I comfortably watch my 37inch at 7 foot and am even thinking of going up to 40, so a 40 should be perfect for you.
If I was buying a 40 inch LCD now, i'd be strongly tempted with the Sony 40W4000/W4500
However, with your sources (mainly SD), I would give strong consideration to a plasma screen.
Sony 32V4000, Sky HD, PS3.
Canon EOS450D, 18-55mm IS Kit Lens + Tamron 70-300mm
robfosters is offline   Reply With Quote
MadDog169 (03-12-2008)
Old 03-12-2008, 7:09 AM   #3 (permalink)
Thanks for your thoughts robfosters. I was out with the tape measure and think that a 32" is all we can reasonably manage in the front room. I know that I can get the LG 32PG6000 for a shade over £400 but was concerned about screen burn. Will plasma deliver markedly superior results with SD sources?
Old 03-12-2008, 8:16 AM   #4 (permalink)
vickster's Avatar
Thanks: Gave 31, Got 452
Yes, sure you can't fit in a Panasonic 37PX80
Panasonic 37PX80 ; V+ VIP package; Sony 350 Blu-ray; Rotel RA-06, RCD-06, B&W 685 and a Sony 26T3000
vickster is offline   Reply With Quote
Old 03-12-2008, 10:53 AM   #5 (permalink)
Screen burn is a lot less of an issue nowadays than it used to be. I have had my Panasonic plasma for well over 2 years and there is not a hint of rentention. As long as you take it easy for the TV's first 200 hours, then you should be fine.
And I personally do feel that plasma deals with SD better than LCD. The gap is closing all the time, but I think plasma still has a winning margin in this area.
I am not sure about the LG. I dont think it's supposed to be top notch in performance. As Vickster said, get your tape measure out and really see if you can squeeze in a 37. You're options open up bigtime for plasma at that size.
If you really can't then you should probably stick to LCD. may I suggest the Panasonic 32LXD80. Amazon.co.uk: Panasonic TX-32LXD80 - 32" Widescreen HD Ready Viera LCD Ready TV - With Freeview: Electronics & Photo
kdl, lcd, panasonic, sony, tx32lxd80
