01-12-2008, 1:09 PM
#2 (permalink)
Thanks: Gave 40, Got 307
Re: Bit of help please - Samsung LCD
Why not get the Sony KDL-40V4000?
01-12-2008, 1:11 PM
#3 (permalink)
Thanks: Gave 10, Got 34
Link at all mate?
And what is so much better about the Sony?
PSN - bigdavecox90
CITY TILL I DIE!
01-12-2008, 1:29 PM
#5 (permalink)
£100 more expensive though mate?
PSN - bigdavecox90
CITY TILL I DIE!
01-12-2008, 2:30 PM
#6 (permalink)
Thanks: Gave 22, Got 6
Go for the LE40 A686, its much better looking & around the same price!
01-12-2008, 4:05 PM
#7 (permalink)
Thanks mate, I'll take a look.
Just found it, but it is £700 whereas the LEA558 is only £559.
PSN - bigdavecox90
CITY TILL I DIE!
01-12-2008, 4:07 PM
#8 (permalink)
Looks arent everything
When your buying from Amazon, make sure you're buying from Amazon UK and not via Amazon Market Place.
PS: The V4000 sits between the the ones you've posted
01-12-2008, 4:14 PM
#9 (permalink)
Thanks: Gave 79, Got 207
If you want to know what the difference is between the A656 and the A558, take a look at the Samsung website and compare the specs.
The A656 has the following over the A558 though:
100hz processing technology
Higher contrast ratio (due to super clear panel)
4 x HDMI ports
Rose Black colour
DNIe Pro picture processing
The A686, has the same internals as the A656 but, is slightly different consmetically. I think it has the square base, as opposed to the A656's eliptical base...
If you consider a Sony though, the one to compare with the A656 is the W4500, not the V4000. The V4000 is comparable to the A558 though.
There are threads for all the panels mentioned on here so, go and have a look at them. You'll get all the info you need.
You may also want to shop around as, you can get the A656 from Dixons for £678 (Pixmania is even cheaper but, I don't think their customer service is very good...)
The A558 is available for around £545 from cheapelectricals too.
Paul
01-12-2008, 4:20 PM
#10 (permalink)
Paul
Cheers mate.
I know it's not alot but I also have £25 worth of vouchers for Amazon, so would knock a little bit more off.
PSN - bigdavecox90
CITY TILL I DIE!
01-12-2008, 4:23 PM
#11 (permalink)
It's always better to buy from places like Amazon and JL purely due to the excellent customer service
01-12-2008, 4:27 PM
#12 (permalink)
Thanks: Gave 13, Got 38
Hi mate, the first TV is better connected with 4HDMI's and has a higher contrast ratio - 50,000:1 vs 30,000:1, although real world contrast is probably nearer 2000:1. Basically a TV with a higher contrast ratio is better at producing deeper blacks, this (in theory) produces more natural overall colour replication.
It is not advertised on your link but it looks as though th TV is also 1080/24 capable.
Thats the basic differences, the LE40A656A may also have an upgraded processing engine but I dont know the TV personally so cannot comment. Why not look for an owners thread here?
What will you mainly use the TV for?
Good Luck
01-12-2008, 4:30 PM
#13 (permalink)
Dixons have good customer service and I've not heard anything to suggest Cheapelectricals don't have either....
It all depends if you want to pay over the odds or not!
Paul
01-12-2008, 4:32 PM
#14 (permalink)
Good Luck
Just watching normal SD channels and playing PS3 and 360 mate.
PSN - bigdavecox90
CITY TILL I DIE!
01-12-2008, 4:57 PM
#15 (permalink)
With this in mind the extra features, (geared towards HD video) and cost don't really seem worthwhile IMO. I'd go for the 558 and save the money... Just my opinion mind...
If you plan to keep the TV for a number of years and may upgrade to Blu-Ray then the extra money spent on the LE40A656A may be worthwhile....
Good Luck
