AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > LCD Televisions
Notices
Panasonic DMP-BD35 or Sony BDP-S550 ?? Waynester Blu-ray Players 22 20-01-2009 8:34 PM
A Petition To Treyarch signs Call Of Duty (COD) Xbox 360 90 17-01-2009 4:22 PM
Links to other websites in your signatures. Your opinions invited Stuart Wright Digital Photography General Chat 76 15-01-2009 9:05 AM
Choosing the right company to upgrade my aerial ? crowds Freeview 8 14-01-2009 3:34 PM
Sony 40W4000 & backlight clouding issue raadek LCD Televisions 11 14-01-2009 1:31 PM
Old 14-01-2009, 1:13 PM   #1 (permalink)
Sony 40w4500 - Dvi to hdmi -Geforce 8800gtx?
Hi, im having abit of trouble with connecting my pc to my tv.
I have a 40inch sony W4500 and my pc has a Geforce 8800gtx. I attempted using a dvi cable to vga (iused a dvi to vga adaptor though) and nothing seemed to work, i also used my flat mates Dvi to vga (actual cable) and it didnt seem to work. (however he did think his cable might be broken)
so i was a bit stumped.
SO i decided to to invest in a dvi to hdmi cable and it kind of works. however none of the reolutions seem to work correctly and the colours are all off.
Then i realised the tv had a pc mode but that only works with the vga input correct?
so im looking for some help with setting it up.
Any ideas or should i just go and buy a new dvi to vga cable?
thanks
scott
p.s. sorry im writting this really quickly because i have uni in five mins.
Scotiax is offline   Reply With Quote
Old 14-01-2009, 1:26 PM   #2 (permalink)
Thanks: Gave 1, Got 1
Re: Sony 40w4500 - Dvi to hdmi -Geforce 8800gtx?
It might be worth getting a DVI to HDMI adapter from reports in the w4500 thread I think it works better than the vga.
Maplin do them
DVI to HDMI Adaptor > Maplin
But I'm sure you could probably get a cheaper one somewhere else.
G
Evilged is offline   Reply With Quote
8800gtx, dvi, geforce, hdmi, sony
