Go Back   AVForums.com > Video Electronics > LCD Televisions
Today's price checkPowered by
Samsung LE-32B450C4
Panasonic Viera TX-L37G10E
Toshiba Regza 32AV615DB
Sony Bravia KDL-40W5500
Samsung LE-32B450C4
Panasonic Viera TX-L32X10
LG 22LH2000
Samsung LE-40B530P7
LG 37LH3000
Panasonic TXL19X10
Samsung LE-37B550
 More...Prices updated November 24th at 5:30am and include delivery.
Singstore connection problem millsman Singstar PS3 9 19-01-2009 4:25 AM
CES 2009 - Toshiba Press Conference Part 1 Phil Hinton Home Cinema and Tech News 2 08-01-2009 1:24 PM
PC to Sony 40V batman1056 LCD Televisions 1 07-01-2009 10:27 PM
Connection Question (Samsung TV, Sony DVD and Sky Plus) Ajackm How do I get the components of my home cinema to work together? 0 07-01-2009 9:12 PM
Media Wireless Copying from PC to PS3, via WMP11 Media Share stormy PS3 Media & Streaming 1 07-01-2009 8:24 PM
Old 07-01-2009, 9:38 PM   #1 (permalink)
Unhappy toshiba 37xv555d pc connection problems
hey all,
i recently bout the 37xv555d off amazon, for use with my 360 and pc, with the pc the main user of the telly.
The 360 connects up fine, ace picture, love it.
But the problem is the pc, i have my pc with a dvi output (nvidia 8600 GT) so i went to my local maplins and bought a dvi to hdmi adapter to attach to the end of my dvi cable. Plugged it in, nothing displays on the hmdi channels or the PC channel, tried it in all the hdmi ports, even the 360 one which i know is fine, nothing. So i thought ok, mabe its the resoultion, so i set it to a different resolution and refresh rate, as per my manual, and still nothing.
Give up on the hdmi, went back to maplins and bought a dvi to vga adapter, and plugged it into the pc connection. Again still nothing, its making me think either the pc is duff, or it wont except my graphics card?? is there anything i can do except try find another pc or laptop to test it with??
has anyone had this trouble??
thanks for reading
dan
danfozzy is offline   Reply With Quote
Old 08-01-2009, 6:24 PM   #2 (permalink)
Re: toshiba 37xv555d pc connection problems
Hi Dan sounds like a similar problem to mine i get desktop working at 1920 x 1080 resolution via dvi-hdmi also from maplin, looks great but it will not display pc games at all, have you tried using a standard vga cable this does work on mine but its low res only
at least you can see that your tv is accepting the signal from your pc.
this problem is giving me the twitch phoned Toshiba support and they were useless good luck m8
Have a look on the forum theres a thread about Tosh Regza tvs
Official Toshiba Regza XV Series Thread
rjd99 is offline   Reply With Quote
Old 13-01-2009, 12:27 PM   #3 (permalink)
Dankeech's Avatar
Thanks: Gave 282, Got 322
Many PC games run at a different / lower resolution til you set them up to the correct resolution in the game settings. I'd suggest connecting a normal monitor to the system, setting the game to work at the supported resolution and refresh for the screen and see if that makes a difference.
Otherwise have you got a PS/2-port-looking type of connector? If so tyour card may well support component-video out via use of a cheap dongle. Much more flexible on resolutions etc and I use component-out from my PC instead of HDMI and works great. I used an 8600GT in another machine for component-out and works great.
Hope that helps.
Dan.
> My kit : Arcam AVR280, Monitor Audio GS20's and RS1's
Dankeech is offline   Reply With Quote
37xv555d, connection, problems, toshiba
