AVForums.com twitter AVForums reviewers are ISF Certified.  Click for more information. AVForums is a member of CEDIA.
AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > LCD Televisions
Notices
Lipsync problems mediapc Home Cinema PCs 7 01-08-2008 10:01 AM
Lipsync problems on MCE goldeneye243 Windows Media Center Edition MCE 2 14-04-2007 8:14 AM
Do you have lipsync problems with the 360 HD-DVD drive? zAndy1 Xbox 360 HD DVD drive 23 04-01-2007 2:36 PM
Is everyone experiencing lipsync problems? zAndy1 Xbox 360 HD DVD drive 13 17-12-2006 3:03 PM
LCD - lipsync problems? Rob100 LCD Televisions 5 18-05-2003 12:45 PM
Old 31-10-2008, 9:21 AM   #1 (permalink)
Thanks: Gave 1, Got 2
Samsung LE40A756 lipsync problems
I recently boought a Samsung LE40A756 but have noticed a severe lipsync issue on Freeview channels. It doesn't always happen but is frequent and doesn't clear easily. Even a channel change doesn't clear it.
Is anyone else experiencing the same problem?
sparkhorse is offline   Reply With Quote
Old 31-10-2008, 11:34 PM   #2 (permalink)
Thanks: Gave 1, Got 6
Re: Samsung LE40A756 lipsync problems
Was looking at the 7 & 8 series and little issues are starting to creep out of the woodwork...
Is it just freeview ? ? Does it do this on other Scart/HDMI players ? ?
jeggsy is offline   Reply With Quote
Old 01-11-2008, 11:03 AM   #3 (permalink)
I have the same problem with my new 40a756! have you find out more about it?
edanielca is offline   Reply With Quote
Old 02-11-2008, 10:03 AM   #4 (permalink)
I've found a workaround - switch to an analogue TV channel and then back to the digital channel - this will clear the issue. (At least until the next time). Switching to external outputs or into standby doesn't clear the issue.
I haven't found a repeatable sequence to reproduce the issue yet though.
External inputs such as HDMI, component, SCART etc. are not affected.
I called the Samsung help line and they told me it was a fault with my tv and I could have it repaired. To me it seems more likely to be a software issue and not a fault with this unit but if I can find a repeatable sequence to produce the issue I will let them come out and have a look.
D Ossett (20-04-2009)
Old 13-11-2008, 11:26 AM   #5 (permalink)
I have the same issue. But only while watching some DVDs with a DVD player connected with AV-Scart and coax sound-cable... some of them, not all of them.. which is strange...
the same DVDs do not have issues while played on my Playstation 3, which is connected with HDMI-cable and optical audio cable...
did you find a solution for this problem?
Master(G) is offline   Reply With Quote
Old 18-11-2008, 5:09 PM   #6 (permalink)
Thanks: Gave 6, Got 13
Got this problem on source via scart and internal digital tuner but only when taking the sound source from the TV to an external amp. Changing the TV sound settings to external. Havent tried via HDMI as taking that sound source direct to amp, as external output from TV is documented as being only 2 channel and wanted full suround signal.
Shows it self as occasionally speach and lips get far enough away to make you wonder, but also seems to come back into sync as well on ots own.
have tried (so far)
taking the sound out from the TV either via coax or optical and still get the problem.
and updating the firmware, which went fine in itself but again did not resolve.
will update as I try differant things
Derek22 is offline   Reply With Quote
Old 18-11-2008, 10:46 PM   #7 (permalink)
where did you get the fw update?
Old 19-11-2008, 6:50 AM   #8 (permalink)
from the samsung website, hope the lnk below works.
But basically support tab, search on your model model, then select download centre and it gives you the manuals. Select the tab for firmware and then follow the instructions.
Download Center SAMSUNG
latest version at this moment in time is 10.10.0
sparkhorse (21-11-2008)
Old 21-11-2008, 6:27 PM   #9 (permalink)
Thumbs up Re: Samsung LE40A756 lipsync problems
I looked in the download centre before but there was no firmware tab then, only manuals.
Anyway I've applied the fw and initial results are positive. It seems to have resolved the major lipsync issue that I was experiencing on DVB-T channels.
lipsync, problems, samsung
