Go Back   AVForums.com > Video Electronics > LCD Televisions
Notices
Today's price checkPowered by
Samsung LE-32B450C4
Sony Bravia KDL-40W5500
Panasonic Viera TX-L37G10E
Panasonic Viera TX-L32X10
Samsung LE-32B450C4
Toshiba Regza 32AV615DB
LG 22LH2000
LG 37LH3000
Samsung LE-40B530P7
Samsung LE-37B550
Panasonic TXL19X10
 More...Prices updated November 21st at 6:30am and include delivery.
Old 20-05-2003, 8:52 PM   #1 (permalink)
stewarthollyhead
Posts: n/a
The best deal 15-17uinch LCD screen ?
anyone know where the best deals are for a new portable TV. I am thinkingof buying an LCD but am reluctant to pay the £700 tags at dixons etc.
also any recommendations on the best actual set for the money
Old 20-05-2003, 8:55 PM   #2 (permalink)
Dutch's Avatar
Thanks: Gave 226, Got 108
Hi Stewart,
INMO the Grundig 17" is the best small LCD TV - even at £700.
Steve
Sky HD, Pioneer LX5090, BDP-05FD, AX4ASi, Oppo BDP-83, Toshiba HD-XA1, XE1, Sony HXD910, Kef iQ7SE (front), Kef iQ6C (centre), Kef Q55 (rear), SVS 2039PC+, Harmony 1000, with Kimber, Supra, Molex and BlueJeans cables
Dutch is offline   Reply With Quote
Old 20-05-2003, 11:18 PM   #3 (permalink)
Super Moderator
Thanks: Gave 464, Got 946
If you can cope with 4x3 you can pick up a quite nice LG item for GBP350-400. For 16x9, the Grundig is probably the best there is at present. There is another thread on here about a 'clone' of the Grundig. Do a search.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 29-05-2003, 7:38 PM   #4 (permalink)
Thanks: Gave 0, Got 10
Have you looked at a Kiss 15" Widescreen Monitor ?
It has Video inputs and is silver
I've seen it on internet suppliers for circa £250
s_tether is offline   Reply With Quote
Old 04-06-2003, 4:16 PM   #5 (permalink)
stewarthollyhead
Posts: n/a
has anyone actually used the KISS tv?
How does it perform compared to the others
Old 04-06-2003, 4:46 PM   #6 (permalink)
kiss lcd
Received my Kiss Coolview from Jasperfish ((£265 + £10 delivery)yesterday. Hooked it up to my dvd player via s-video (can do RGB via din plug but don't have necessary cable [where can I get a scart to din cable, anyone?] and the picture is, IMHO, really rather good. The contrast / brightness ranges are not great, but they will do for me. Also hooked it up to freeview (scart to phono cable) and again I was impressed by the image on display.
It has normal, anamorphic, 4:3 and zoom modes - and you can customize screen settings via the menu (tint, colour, linear/crt mode etc). Have ordered a Packard Bell flat panel speaker package from Dixons (£19.95) to provide sound.
£275 + £19.95 for a widescreen monitor and speakers - no way would I think about paying £400 plus for any other model! This is definitely the way forward!
The screen looks great and the wife loves it - wonders will never cease!
dexter is offline   Reply With Quote
Old 05-06-2003, 3:37 AM   #7 (permalink)
Thanks: Gave 10, Got 50
I also have a Coolview got it from Monitor Warehouse for £256 (price matched against Scan). The picture is fine for a Bedroom set and it is a fabulous piece of design work. The best feature is the stand which folds right back to become the wall mounting bracket. It has a 3 year waranty as well (+1 year from Barclaycard).
Bassbin is offline   Reply With Quote
Old 05-06-2003, 2:57 PM   #8 (permalink)
stewarthollyhead
Posts: n/a
does it need an additional TV tuner/freeview box? or has it got a built in tuner.
Sounds like it also comes without sound?
Once i bought the TV tuner and speakers isnt that nearly as much as£450 sets?
Old 05-06-2003, 4:12 PM   #9 (permalink)
wandersen
Posts: n/a
Look on www.letsbuyit.com - they have the Samsungs on there for a very good price at the mo - from £365 for the standard 15 inch to £549 for the W/S 17.
Old 05-06-2003, 4:37 PM   #10 (permalink)
If you have a video player you can hook this up (scart to phono) to the coolview monitor and use this as the tuner. I tried this and a digibox and both worked fine.
£260 screen
£20 flat panel + subwoofer packard bell speakers
(£50 for cheap vcr?)
Assuming you have a video then this is still significantly less than an lcd screen with tuner and speakers built in. Most £400 lcd televisions are 4:3 ratio - remember that the coolview is 16:9!
Hope this clears things up for you.
Old 05-06-2003, 6:22 PM   #11 (permalink)
I toyed with getting the Samsung but decided that the Coolview was the best bet. However £365 is a very good deal. If you just want a TV with no other equipment then it may be fine but the sound will be very poor (due to the size of the speakers).
I'm using my Coolview with a spare nicam video (with scart to phono) and a Sony CMT-M90DVD system which I bought last week from Curry's for £159. This gives me TV, VCR, DVD, CD, Tape, Tuner and Timer for less than £500 which is pretty unbeatable.
The only thing I may change is the speakers that came with the Sony, they're not bad but the cabinets are quite deep. I think I've got a pair of JBL Control 1s lying a round somewhere that might do the trick.
Old 06-06-2003, 11:48 PM   #12 (permalink)
Thanks: Gave 11, Got 28
I saw a KISS WS panel in morgans yesterday, not sure whether it was the same one here (15.2 inch cool something), I felt it was off the top field re quality but was well priced
The Beekeeper is offline   Reply With Quote
Old 07-06-2003, 4:46 PM   #13 (permalink)
The one in Morgan's is the same item. That image quality is only average but it does offer a lot of user adjustment. As a computer monitor it is a bad choice as the image is not very bright (not such a problem for film/tv).
1517uinch, deal, lcd, screen
