AVForums.com twitter AVForums reviewers are ISF Certified.  Click for more information. AVForums is a member of CEDIA.
AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > LCD Televisions
Notices
Sony Bravia W/X3000 series Auto-dimming - possible workaround? Pallaris LCD Televisions 15 28-04-2009 6:23 AM
Sony X3000/X3500 Series Thread ChrisGgr LCD Televisions 9169 16-12-2008 9:30 PM
Sony X3000/3500 Series Vs W3000 Series davebeef1 LCD Televisions 3 28-11-2007 8:19 PM
New Sony W3000 and X3000-series LCD TV's announced - PLEASE USE NEW THREADS vowani LCD Televisions 365 08-08-2007 2:59 PM
Sony x3000 Series & xXBR stevie_velvet LCD Televisions 20 01-03-2007 7:52 PM
Old 10-05-2008, 11:20 AM   #1 (permalink)
jameslindsey's Avatar
Thanks: Gave 10, Got 19
Sony X3000 series settings
Please forgive me for starting a new thread but the "official thread" is massive and it's difficult to extract all the relevant data for tuning the TV.
I have the 40X3000 and think its fantastic, but it can look horrible (mine did) on the shipped picture settings. After a couple of months of playing around with the settings I reckon I've got about the best picture I can, using settings based on what other people have posted on the forums. I propose people (if they're interested) post their settings as per the format below so that it will help others to get the best out of their telly. Rather than could the data by getting into a discussion about the good and bad points.
Product info
1: 40x3000
2: 460XXXX
3: WJ-BA-A-HOI-O-FYB-O
Source
Topfield Freeview SD PVR SCART RGB
Settings
Picture Mode: Cinema
Backlight: 5
Contrast: 85
Brightness: 39
Colour: 47
Colour Temp: Warm2
Sharpness: 50
Noise Reduction: Off
MPEG Noise Reduction: Off
DRC Mode: Off
Advanced Settings
Black Correct: Off
Contrast Enhancer: Off
Gamma: Off
Clear White: Off
Colour Space: Standard
Live Colour: Off
White Balance:Rgain 0 Ggain -4 Bgain 0 Rbias -1 Gbias 0 Bbias 0
Detail Enhancer: Off
Edge Enhancer: Off
Video Settings
Motion Enhancer: Off
Film Mode: Auto 1
Game Mode: Off
Colour Matrix: ITU601
Colour System: Auto
Setup
Power Saving: Off
Light Sensor: Off
Notes
TV suffers from slight torchlight patterns on a black screen, but not noticeable in normal viewing.
Motion smearing is also present and has been pretty bad at times, but tweaking to these settings seems to have reduced it to barely noticeable. I think this may be affected by source quality & differences as well as a TV issue. Possibly due to a digital picture being converted to analogue in the PVR being sent to the TV and being converted back to digital again.
When I'm happy with my PS2 & DVD settings I'll also post here.
Sony KDL-X3000, Pioneer DVD-757Ai, VSX -D2011 Biamped into Rogers LS33. AB33 twin Passive subs, Centre speaker & LS1 rears.Toppy, PS2, Pronto, Nikon D-200, 18-200mm AFS VRii, Coolpix S1.
jameslindsey is offline   Reply With Quote
Old 10-05-2008, 11:30 AM   #2 (permalink)
Thanks: Gave 93, Got 101
Re: Sony X3000 series settings
Thanks for the settings details but just looking at them, I know it wouldn't work for my X3000.
It would be way too bright with Power saving off and I have my colour set to 70, on 47 everything looks too dull.
smokedog is offline   Reply With Quote
Old 10-05-2008, 3:03 PM   #3 (permalink)
Will completely depend upon set and ambience. Blacks are definitely black with this setup on my TV it does have a window behind it though.
Old 22-06-2008, 1:07 PM   #4 (permalink)
retro41's Avatar
Thanks: Gave 11, Got 25
Freeview
(Integrated)Picture
Backlight: Min
Contrast: 87
Brightness: 51
Colour: 53
Colour Temp: Warm2
Sharpness: Min
DRC Mode: Mode 1
DRC Palette
Reality: 20
Clarity: 100
Advanced Settings
Black Correct: Off
Gamma: Off
Clear White: Off
Live Colour: Off
White Balance:Rgain -5 Ggain 0 Bgain -1 Rbias +2 Gbias 0 Bbias -1
Edge Enhancer: Off
Video Settings
Motion Enhancer: Standard
Film Mode: Off
Setup
Power Saving: Off
Light Sensor: On
Game (PS3)
Backlight: 2
Contrast: 90
Brightness: 52
Colour: 57
Colour Temp: Warm2
Sharpness: Min
Advanced Settings
Black Correct: Off
Gamma: Off
Clear White: Off
Live Colour: Off
White Balance:Rgain -5 Ggain 0 Bgain -2 Rbias +2 Gbias 0 Bbias +1
Edge Enhancer: Off
Video Settings
Film Mode: Off
Game Mode: On
Setup
Power Saving: Off
Light Sensor: On
Comments
I find these ideal for my maximum viewing distance of 8ft.
The Light Sensor saves time from adjusting the backlight manually all the time.
DRC mode helps with freeview picture quality, channels and programmes vary.
Turned over to Neighbours a couple of weeks ago and the depth in skin detail was almost HD-like quality, I was shocked.
Football is shocking on freeview.
The motion enhancer set to Standard helps when there is text scrolling, or signs when camera pans past. Making them more readable, compared to the unreadable blur when its turned off.
SONY BRAVIA 40X3000 | PS3 60GB | DUALSHOCK 3
The Setup
retro41 is offline   Reply With Quote
merveilles (19-11-2008), redders1 (08-10-2008)
Old 08-10-2008, 3:58 PM   #5 (permalink)
Thanks: Gave 6, Got 0
Thanks retro41 those setting worked a treat for my PS3 and X360, still stunned how it looks.
All I need now is one for sky hd.
redders1 is offline   Reply With Quote
Old 08-10-2008, 4:22 PM   #6 (permalink)
Thanks: Gave 4, Got 17
I would go to the review for the x3500 on HDTVTEST.co.uk. Those settings listed there give a very good picture.
Sony KDL40X3500 Settings
sr20 is offline   Reply With Quote
Old 08-10-2008, 5:45 PM   #7 (permalink)
Yep they sure do...
series, settings, sony, x3000
