AVForums.com twitter AVForums reviewers are ISF Certified.  Click for more information. AVForums is a member of CEDIA.
AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > LCD Televisions
Notices
Sony W5500 (32/37/40/46/52-inch) Tejstar Home Cinema and Tech News 35 01-07-2009 4:16 PM
Have Sony scrapped 26"? Limerick LCD Televisions 4 17-02-2009 7:10 PM
Sky to replace certain HD boxes prinjm Sky HD 8 17-02-2009 11:17 AM
Closed Thread
Old 14-11-2008, 7:06 PM   #4426 (permalink)
Thanks: Gave 0, Got 8
re: Sony 32/40/46/52 W4000 Full HD(Bravia Engine 2,33.000:1 Contrast) Thread
Set up my new Sony 40W4500 today (bought from RS) and have to report that so far no sign of clouding or backlight bleed. Great picture and good sound. At the moment I have a Sky+ box so I can't vouch for the HD picture yet. Sky HD comming on 20th December so I'll have to wait til then for Hi Def. On the presant showing, I am sure Hi Def will be fantastic.
Highgord is offline
Old 14-11-2008, 9:19 PM   #4427 (permalink)
Thanks: Gave 49, Got 6
I know you can connect your digital camera to this tv to view your photos but what i wanted to know is do they show up in full screen?and can you use them in the picture frame mode?
philip birdi is offline
Old 16-11-2008, 1:05 PM   #4428 (permalink)
Orbitalzone's Avatar
Thanks: Gave 1, Got 44
Connecting a USB memory stick I found that it seems to show the image at the original resolution, so a 1920x1080 fills the screen but a 1024x768 is centred with black edges all around. I haven't (yet) found a way to fullscreen it even though it shows an option to this.
Any information given by Orbitalzone should be considered unreliable, innaccurate, questionable and probably down right wrong. Please disregard all information and destroy Immediately.
Orbitalzone is offline
philip birdi (16-11-2008)
Old 16-11-2008, 7:45 PM   #4429 (permalink)
Thanks: Gave 4, Got 3
I definately got a problem with with full pixel mode in the menu. I understand it's great for HD etc, but on sd I get those light dashes on the top left of the tv. The solution is obviously to turn it off for sd, but when I turn it off, change to another scource (and or back), or switch set off and then on (or from standby), tv always automatically switches full pixel back on. I have 3 devices linked to the tv all by hdmi..freesat, ps3, recordable dvd. It is satrting to get extremely annoying, as I'm having to switch off full pixel many times daily. Also I dont believe that the light dashes are to do with the scource because if you zoom in the sd picture, the light dashes remain exactly where they were before, even though the picture is enlarged. You'd think that there would be a vertical adjustement for everything in the menu to overcome this or maybe this inability of the tv to not remember that full pixel has been turned off is particular to my tv only, Drac
Dracutus is offline
Old 17-11-2008, 2:39 PM   #4430 (permalink)
Thanks: Gave 5, Got 7
Hello guys is it possible to get 1080p through VGA on the Sony KDL 32W4000E Tv?
Tv would be mainly used for gaming on the Xbox 360 and I use a VGA cable with my 360..
lemmykoopa is offline
Old 17-11-2008, 7:16 PM   #4431 (permalink)
tidytrev's Avatar
Thanks: Gave 1, Got 10
yup although you do have to turn tv off and on again the first time to get it to work
tidytrev is offline
Old 18-11-2008, 10:56 AM   #4432 (permalink)
Owen824's Avatar
Thanks: Gave 89, Got 126
I have just ordered the 46w4000 to use in the showhouses and was wondering if the w4500 is a big step up in regards to pic quality/performance? was just an impulse buy as we got a good deal on it.
Sony 40X3500, Denon DVD 2930, Xbox 360, Nintendo Wii and all the rest has been sold to make way for new and improved equipment eventually when house is ready...
Feel free to help me with my My Cammo Estate Development Project here
Owen824 is online now
Old 18-11-2008, 2:26 PM   #4433 (permalink)
Thanks: Gave 16, Got 6
W4500 REVIEW
Sony KDL40W4500 / KDL40W4500U Review
W4000 REVIEW
Sony KDL40W4000 Review: 40" Bravia 1080p LCD HDTV Panel
They both have a balck level of 0.05cd/m so your paying more for the 100hz and design. The W4500 seems to suffer from input lag aswell as a worse case of clouding, but im not 100% sure on the latter.
vishnu02 is offline
Old 18-11-2008, 3:57 PM   #4434 (permalink)
ChrisGgr's Avatar
Thanks: Gave 885, Got 1,544
the W4500 has about the same lag as W4000 with game mode so no issue here and clouding cases arent more than those in W4000
SONY KDL-32W4000,SONY PS3 160GB,SONY KV-32FQ85,SONY KV-29FX66,SONY RDR-GX210/S
CAR:Alfa Romeo 159 1.8 140PS progression
ChrisGgr is offline
Old 18-11-2008, 6:56 PM   #4435 (permalink)
Thanks: Gave 7, Got 0
hi all
just got my 52w4000 today after 13 weeks of waiting
seems a great set it replaces my 46" w2000 model which has gone elsewhere
sound seems a liitle quieter with less adjustments thsn the the w2000 series
i did consider the w4500 but kept my original order
anyone point me to the link for best settings?
cheers
jh
jph160 is offline
Old 19-11-2008, 12:34 PM   #4436 (permalink)
i plug mi htpc with a ati radeon 9600xt by hdmi-dvi cable, and a sony tft 17" by vga in extended mode using ati hydravision. The high resolution i can get in my 32w4000 is 1920x1080p@24hz, and when i select in ati ccc 1080@50hz or 60hz the screen goes black. should be able to get this frecuencys at 1080p via dvi cable with my ghrapic card in extended mode?
Garfi0 is offline
Old 20-11-2008, 11:14 AM   #4437 (permalink)
Hello i can configure mi resolution to 1080p 50 and 60hz, but i have another problem. When i select 1080p24 i got 2 or 3 pixels of overscan on the left side of the screen, en when i select 1080p50 or 60 i have the same result y the other sido of the screen. I have a ati radeon 9600xt with the latest drivers, and i use a dvi-hdmi converter connected to the dvi out on the graphic card and a cheap hdmi cable . Anyone has observed the same issue?
Garfi0 is offline
Old 20-11-2008, 10:36 PM   #4438 (permalink)
Thanks: Gave 4, Got 1
Hey guys, I've been wondering, for anyone who uses a Xbox 360 with HDMI on their W4000....
What resolution do you set your 360 to? I had mine set to 1080p for quite a while allowing the console to do the scaling work but I recently changed to 720p on the console since most games are that resolution natively and I am pretty sure the image is ever so slightly crisper.
Does anyone else have any thoughts on this?
Also, with the new NXE update does anyone know what the best colour settings to use are with the W4000?
beardtm is offline
Old 21-11-2008, 12:07 AM   #4439 (permalink)
tidytrev's Avatar
i dont know if this is true with the xbox over hdmi but my ps3 over hdmi and xbox over vga switch to 720p automaticaly when presented with 720p content
edit: my bad, the xbox doesnt switch with the vga lead, can anyone confirm with hdmi?
tidytrev is offline
Old 21-11-2008, 7:17 AM   #4440 (permalink)
Thanks: Gave 5, Got 2
Nope, the xbox just outputs at a single specified resolution.
I've tried 720p but it seems to display in 4:3, unless I manually switch it - anyone else had this?
I'd imagine using 720p for everything but 1080p HD video would be the better option as the TV will almost certainly have a better scaler.
psyduck is offline
audio, contrast, digital, engine, full, hdbravia, hdmi, kdl, official, or 52, problem, sony, thread, w4000
